Which Side Of 2x8 Is Crown? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-11-2008, 02:09 PM   #1
Which side of 2x8 is crown?
I'm sistering some joists, and know to put them crown side up. Some (few) have visible crowns. Most do not - they're perfectly straight! Is there a way to tell which side is (or will) crown?
Also, they're larger than my older existing 2x8 joists which are 7" tall. These new ones are 7 1/8" tall. Is this because of higher humidity? Will they eventually shrink?
Thanks,
John
jdelisle is offline   Reply With Quote
Old 01-11-2008, 05:41 PM   #2
Woodworker and Contractor
Kingfisher's Avatar
Rewards Points: 150
they should be 7 1/4" and humidity will not change that more then a 1/16" crown the best you can, if they are straight go with the center or heart on the bottom.
Kingfisher is offline   Reply With Quote
Old 01-12-2008, 08:50 AM   #3
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,374
Good question, I take the time at HD to select the straightest lumber I can find and most of the time I can't tell the crown side. Thanks for the tip King.
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
crown molding meets window trim sonofthetonsured Carpentry 13 03-19-2011 12:33 PM
Whirlpool side by side icemaker-No Ice wtoler Appliances 2 09-08-2007 09:05 AM
Side By side refrigerator Susie Q Appliances 6 08-31-2007 03:26 PM
Cathedral ceiling without sofit vent on one side ChrisO Roofing/Siding 3 01-31-2007 10:51 AM
Crown Caulking Not Sure Carpentry 3 08-18-2006 09:40 PM
