Shower Windows - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-05-2008, 05:02 PM   #1
Shower Windows
I'm remodeling a master bath and will end up with a 5/5 walk in shower. the current windows are cheap aluminum buillder grade that are 12 yrs old. the question is, should I try to replace them with a a standard type window that would have an internal shade for privacy or should I go with glass block that could allow for complete privacy and be less likely to develope leaks? the two window rough openings ar 43 1/4 by 51 1/4.
COHIBA1 is offline   Reply With Quote
Old 05-05-2008, 05:13 PM   #2
General Contractor
MacRoadie's Avatar
If your goal is to avoid leaks, then avoid the glass block. Block leaks more than any other window system I've ever seen. In fact, glass blocks are source of the only window leak I've ever seen that leaked from the inside a shower of course.
MacRoadie is offline   Reply With Quote
replace anderson windows hobbyguy2002 Remodeling 13 12-06-2009 09:34 PM
First time vinyl siding newbie plus windows justdon Remodeling 9 02-06-2008 06:39 PM
Replacing "Aluminum Flared" Windows? bahaisamurai Building & Construction 6 06-07-2007 10:23 AM
new windows juliejules4 HVAC 12 12-06-2006 01:37 PM
How do I install new windows? RickT Carpentry 17 10-12-2006 06:06 PM
