Shower Wall Stability - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-06-2010, 12:55 PM   #1
Rewards Points: 270
shower wall stability
hi all - I saw this older thread in the forum here and it's pretty close to what I'm trying to do in my bathroom
Shower Half Wall Framing
I have the same situation except that the wall in question (approx 4') may end up being a full height (approx 84") + tile, as opposed to half height + glass on top. So - same issue (wall stability), but taller wall.
If I run the wall studs down in to the floor space and brace them against floor joists and / or blocking, etc as suggested in the thread referenced above, will it be solid enough even if the wall is 80" high? I don't want the wall to go right up to the ceiling, which would make this rock solid, but it would look kinda crappy in our case. We would like hang a full height glass door approx 24" wide x 80" high off this same wall so the free end has to be pretty stable I assume.
I'd like to use 2x4 to frame the wall, to maximize shower space (as opposed to 2x6). Underneath is the crawl space with 2x12 floor joists + blocking already in place @ 6' mid span (I really overbuilt it) so I have a very solid floor with lots to brace against if I do this.
Thanks for any feedback
-randy
rtoni is offline   Reply With Quote
Old 12-06-2010, 05:36 PM   #2
Rewards Points: 5,336
I'd use a steel box bolted to the joists and run up the inside of the wall if you're going to hang a door on it. I'd also screw and glue a plywood skin on both sides.
Ron
Old 12-08-2010, 11:28 AM   #3
Rewards Points: 270
Thanks Ron - by steel box you mean a length of square steel tubing or actually fabricating a box to fit exactly between the joists? sorry if I'm not understanding correctly...
Old 12-08-2010, 12:45 PM   #4
I was just speaking of the square steel tubing as it requires no welding skill. But, if you have a welder and want to go to the effort.....
Ron
Old 12-08-2010, 01:00 PM   #5
Rewards Points: 270
I'm not much of a welder - I'll stick with the tubing which I can easily pick up on the way out next time. Plywood also noted. thanks for the tips...
Old 01-27-2011, 12:39 PM   #6
Rewards Points: 270
I'm resurrecting this thread as I have another related question.
Assuming I build my 2 shower wing walls (framed and tiled - using the advice here - thanks) to a full height (say, 84") but I do not install a door. Instead, I have a walk in shower. Could I add a shower rod (not sure if that's what it would be called in this case) that connects / ties the top ends of the 2 wing walls together (e.g. across the top of the walkway / opening). This could serve as a curtain rod (should I decide to hang a curtain there at some point) and also stabilize the top of the wall sections, kinda like a top rail should do in a glass enclosure...?
Really trying to squeeze the budget now and the walk in option seems kinda cool. Just not sure if the top rod / rail would spoil it.
Does that make sense? Would this look cheezy? It seems like a really easy way to add some extra stability to the walls. You can't swing a dead cat without hitting a thousand pics of glass enclosures but I'm not having much luck finding an example of what I'm trying to describe. Maybe that should tell me something..?
Old 01-27-2011, 12:47 PM   #7
These rods are not built to control wing walls. They are usually 2 escutcheon plates that have a rod in the center. The rod just floats in the plates. You would need something like a threaded pipe with flanges screwed into the ends that were then screwed into the wall to tie them together.
Decorative solutions are rarely structural( and visa versa).
Ronron
Old 01-27-2011, 04:11 PM   #8
Rewards Points: 270
thanks Ron - i see what you're saying. I guess there's no product out there that's both (decorative and structural)? in this case? I'm just kicking ideas around - thanks for the feedback.
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 6 05-19-2017 04:53 PM
Problem with shower pan and drain ohiogirl1965 Plumbing 1 06-07-2010 06:33 AM
Help us make a remodel decision for selling home pleas 3detailer Kitchen & Bath Remodeling 11 04-27-2010 11:36 AM
shower head pipe snap inside of wall? snosurfa7 Plumbing 3 06-06-2009 09:15 PM
Water seeped through tiles in shower, wall ruined, need help. doogie88 Building & Construction 39 10-07-2008 04:13 PM
