Shower Moisture Barrier Question - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-06-2013, 10:28 PM   #1
Rewards Points: 396
Shower moisture barrier question
When you install poly sheeting behind cement board I understand you should let the sheeting drape over the tub/shower lip then cut off remaining afterwards. Reason behind this is so if water does get behind the cement board and to the sheeting it will flow back out over the lip into the tub/shower. Here is what I am confused by. After the cement board is installed and tiling is done your obviously supposed to caulk the bottom gap so when you do that your basically sealing that gap up so even if water did reach the sheeting how could it drain out?
detroittigerfan is offline   Reply With Quote
Old 08-07-2013, 05:47 AM   #2
Rewards Points: 13,450
Should have waterproofed the face of the tile board not add a vapor barrier behind it.
Tile board and grout are not waterproof so why allow it to work it's way in behind the tile board so mold can form on the back side?
The way your suggesting you would have to leave gaps in the caulking to drain it.
Old 08-07-2013, 07:27 AM   #3
DIY staff
Rewards Points: 7,174
What Joe said----
The plastic behind the board is not needed if you waterproof the face of the board---
I never could see the benefit of plastic over the studs---
Old 08-07-2013, 09:55 AM   #4
Rewards Points: 396
Originally Posted by oh'mike View Post
What Joe said----
Ok and doing plastic sheeting behind the board and water proofing the front is a no no, correct?
Old 08-07-2013, 09:58 AM   #5
That would be a double vapor barrier which is sure to cause issues.
Old 08-07-2013, 09:58 AM   #6
DIY staff
It's not the best practice, but if you waterproof correctly, I doubt of any thing bad will happen---the plastic is perforated with nails and screws and no moisture will reach the plastic===
Shower Pan Question SER56 Kitchen & Bath Remodeling 6 03-22-2012 12:29 PM
Custom Shower Plumbing Question PhilStubbs Plumbing 0 04-24-2011 09:39 PM
To Vapor Barrier Or Not to Vapor Barrier, That Is The Question. joegambler Building & Construction 5 09-18-2009 09:40 PM
AAV Shower Question PADIY Plumbing 8 01-20-2009 04:49 PM
Shower Arm Question brakea Plumbing 2 01-02-2009 05:58 PM
