Shower Enclosure Issue Where Wall Meets The Floor - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-26-2013, 12:33 AM   #1
Shower enclosure issue where wall meets the floor
After tearing down the existing walls in my shower enclosure, I found that in the original installation, the contractor put up the wonder board walls first, then poured the concrete floor, so now I have nearly a 3/4" gap between the stud wall and the finished floor. Should I just leave this gap there an bring the new backer board down to the level of the floor (Option A)? Or should I fill in this gap with concrete before hanging the new backer board (Option B)?
There are parts of the floor where the old backer board could not be removed, so I'm not able to push the new backer board down into the space uniformly. The shower pan membrane is under the concrete floor and extends up the wall about 8", so I feel ok if water gets into the space.
Ideas? Advice?
Thanks.
achiang is offline   Reply With Quote
Old 05-26-2013, 04:59 PM   #2
Rewards Points: 282
dry set mortar would likely be appropriate for this task...and you definitely dont want a ditch there, that was a terrible install.
i think kerdi set would work well here (just my preference for unmodified)....and kerdi-set is recommended by schluter to extend a kerdi pan if you need too....although not your exact application, it seems appropriate.
dont let that CBU get close to the floor grade (i'm a kerdi fan, so I would just do that for a bullet proof install).
jcrack_corn is offline   Reply With Quote
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 6 05-19-2017 04:53 PM
Replacing Garden Tub w/Tile Shower on a Slab floor.. Need Help!! cufflinks General DIY Discussions 16 05-20-2013 06:16 AM
Marble Floor, Walk-in Shower...replace or tile over? CafeBusy Tiling, ceramics, marble 8 04-25-2013 09:14 PM
Please help with retaining wall / patio issue that has arisen. coderguy Landscaping & Lawn Care 3 05-26-2012 04:45 PM
shower wall stability rtoni Building & Construction 7 01-27-2011 04:11 PM
