Old 05-20-2011, 09:35 AM   #1
Shower curtain rod problem
I have a bathroom in my house. The bathtub is the normal 60", but behind it is a small sitting area/ledge (17"). So that makes the entire opening 77" wide! To make the problem worse is the wall next to the bathtub has beautiful tiles laid into a really nice design. So I don't want to get one that turn 90 degrees (because I'd have to drill into the nice tiles).
I can see if I can find a shower curtain rod that can accommodate such a large opening (77") but even if I did, I can find a curtain that can keep the water from escaping/splashing from the tub area but not from the ledge. I won't be able to keep the water from escaping from the ledge.
Anyone have any ideas how I can keep water from escaping from the tub and ledge area?
See attached for picture of the layout.
edta1 is offline   Reply With Quote
Old 05-20-2011, 10:10 AM   #2
Old School
Willie T's Avatar
Use two shower curtains? Maybe open them from the center like a theater curtain?
Willie T
Old 05-20-2011, 10:25 AM   #3
I kind of like that. So the one over the ledge (it's about 4-6" taller than the bathtub) will be 1 curtain, and the tub will be another? But then everytime we replace that one curtain (the one over the ledge), we'd have to cut it a bit?
Old 05-20-2011, 11:39 AM   #4
Learning by Doing
Leah Frances's Avatar
How often do you replace curtains? Get two you like and look good cut it. Then get a pair of cheap washable liners, cut them to fit and wash them as needed.
I've had the same shower curtains for 5 years. Don't anticipate having to change it any time soon.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 05-20-2011, 12:41 PM   #5
Make your own curtain rod from closet rods or something similiar and mount it to the ceiling.
Ron
Old 05-20-2011, 04:23 PM   #6
Tizzer's Avatar
I like the ceiling mount idea unless the ceiling is really tall.
Tizzer is offline   Reply With Quote
Cross connection problem? kissiffer4 Plumbing 20 03-31-2011 09:18 AM
hanging a shower curtain rod on tile darsunt Plumbing 7 06-22-2010 08:15 AM
Shower unit from Costco.door problem Carol f Plumbing 1 06-12-2010 05:29 PM
Problem with shower pan and drain ohiogirl1965 Plumbing 1 06-07-2010 07:33 AM
Grout peeling out from shower floor tiles. What's the problem? hellstorm Flooring 6 10-21-2009 10:15 PM
