Shower Ceiling Hight ???? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-07-2011, 02:46 PM   #1
Rewards Points: 89
Question
shower ceiling hight ????
I have a new 2nd floor addition, including a shower. My ceiling to floor height is 9.5, without drywall or tile. I like the ceiling height of the rooms. But as I am looking at the shower, it seems very tall when thinking about, heat or warm air loss (in the winter) the ceiling light. Is there a standard shower ceiling height? Can someone give me any recommendations?
chipraynor is offline   Reply With Quote
Old 09-07-2011, 03:30 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
If there was a "standard" it would be the room height. You can lower it if you think that little bit of additional height is going to make any kind of a difference in the overall scheme of things. It's not.
Typically most ceilings are 96" if that helps you.
XXX
Old 09-07-2011, 04:21 PM   #3
Rewards Points: 5,336
The height of the ceiling isn't that important. I have a second floor bath with that height and it's fine.
The shower area is warm as long as the doors are shut.
Ron
B. Franklin 1759
Old 09-07-2011, 08:47 PM   #4
I have similar ceiling height in my recently remodeled bathroom. I chose to lower the ceiling inside the shower encloser, both because it seemed too high, and because that gave me room to put the vent fan in with a straight 4 foot run to the exterior. If I were to do it over again, I might even lower the ceiling a little more. And run the tile all the way up......stopping it low caused me some major PITA.
1910NE is offline   Reply With Quote
Old 09-07-2011, 09:23 PM   #5
Rewards Points: 6,652
The part that is important, is the height of the shower head. I am 6'-4", and I really hate it, when I stay places, the shower head is about at my shoulder height. That means that I practically have to get on my knees to take a shower. Just a reminder on that part. As for heat loss, it is how well insulated the structure is, and that you take into consideration, that you loose heat through the exhaust vent, if there is no flapper on it, or if it is not insulated.
Also with the humidity from taking showers, it goes in line with how well it is ventilated, and how tight the structure is. If there is not enough turn over air to keep fresh air coming into the house, or specifically the second floor, you could end up with all air moving from the downstairs to the upstairs, and nothing to pull that stagnant air out of there.
Paint peeling off Bathroom Ceiling!!! armen30 Painting 17 12-08-2011 08:26 AM
Ceiling condensation icemand Building & Construction 1 12-15-2009 05:16 AM
Can I install 12x12 porcelain tile on a shower wall or ceiling? dezigner80 Remodeling 6 09-15-2009 12:05 PM
Ceiling Mounted Shower Head bounc4 Plumbing 1 01-16-2009 05:30 PM
tiling a shower ceiling.... anedoll Remodeling 1 01-01-2007 07:04 AM
