Shower - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-06-2010, 12:01 PM   #1
shower
I am putting a tile shower in my house the one wall is the outer wall. It is brick the tub sits about 1 inch from it. The way it was previous was tile on concrete put this crumbled the house is about 50 years old. What are my options?
thank you for your input
dave
dschwantner is offline   Reply With Quote
Old 03-06-2010, 08:30 PM   #2
DIY staff
Rewards Points: 7,174
Do you have a picture? This can be difficult--plaster lath(expanded mesh) and several coats of morter may be the best solution--hard to offer advice without seeing the situation--Mike--
Old 03-07-2010, 06:35 AM   #3
ccarlisle's Avatar
You may have moisture issues with the tub being so close to the brick so I assume you are going to cover it...Cement backer board, Schluter membrane, thinset, tile.
You must waterproof it and even put a vapour barrier there too but since we don't know where you are, I'll leave that.
“The average American woman is about 25 pounds heavier than she was in 1960...Recognizing obesity as a disease will help change the way the medical community tackles this complex issue that affects approximately 1 in 3 Americans,”
ccarlisle is offline   Reply With Quote
creating new shower floor/ slope??? Bob Funk Plumbing 2 03-01-2010 04:22 PM
Bathroom shower surround StevePax General DIY Discussions 0 11-12-2009 12:31 PM
How to tile around a Pre fab shower base geoffthemonk Building & Construction 1 11-07-2009 09:10 AM
Tile Baseboard on outside of plastic shower pan at linoleum joint? GaryS Tiling, ceramics, marble 2 07-26-2009 12:39 PM
redoing basement shower - basic questions (relocating drain/options I have) mslide Plumbing 5 10-28-2008 10:42 AM
