-   -   Should we really install bow window this way? (http://www.diychatroom.com/f19/should-we-really-install-bow-window-way-81526/)
JBrowning 09-15-2010 08:42 PM
Im going to help a couple buddies install a wide bow window in an old opening. They have more experience, but Im wondering about part of their plan and would like some advice on that.
The wall beneath the opening is 4 thick concrete block, with brick facing. Theres currently a 2 concrete slab sill under the existing window, extending from inner edge of wall to beyond the brick. Plan is to leave that, which sounds fine to me, since most big window replacements in that neighborhood have done that. But the slab is set at a pretty steep pitch, and the window base is flat, and the question is how to deal with that wedge-shaped gap when giving the window solid support over the wall. (They say were going to be adding braces and insulation underneath, but Ill be ignoring that here, for simplicity.)
Their plan is, I hope, clear in the diagram:
http://i898.photobucket.com/albums/a...ingdiagram.jpg
Three boards will be added under the window seat, running across the window bottom: A 2X6 sill plate, laid flat on the concrete slab, so it has the same steep pitch as the slab. A thinner, narrower board on top of that, to provide a flat surface for some of the seat near the outer part of the wall. And a narrower board between the wood sill and that added board, to force the board level. Shimming as needed. The plan is to use no bottom fasteners at all to secure the seatboard, aside from some wood screws driven at an angle through the seatboard edge and into the 2X. That way the seat board finish wont be marred at all, and the screws will be covered by the casing.
Before I heard that, I had assumed we were going to cut thick wedges to fill the gap between concrete and wood sills, and space them periodically perpendicular to the wall. That way the whole 2X6 would be flat and resting on flat-topped wedges (or nearly so, there would still be thin shims needed no doubt), which sounds a lot firmer to me. The way they plan to do it, the seat doesnt have any true flat base anywhere over the wall, because when you look at the diagram its basically boards resting on board corners only. Are just board corners strong enough? (And straight enough? Little strips of board edge corner that have pulled off would change the straightness quite a bit, Id think.) And it seems like itd be easier to fit in some insulation using wedges instead of boards. Id also like to see more seatboard fasteners than just the diagonal wood screws, some nails near the outer edge of the wall.
What would you do?
forresth 09-15-2010 08:57 PM
looks a bit half-assed, but if there is good bracing further outboard, I wouldn't be overly concerned. don't let them do the bracing half-assed too.
I'd feal better with a 2x4 vertically, ripped at the angle added in nearer the outer portion.
Willie T 09-15-2010 09:48 PM
I agree with Forresth, a tall, vertical piece is much better on the outside. Don't forget to cut a groove in the bottom of the seat board too..... to kill any dripping rain water run-back.
JBrowning 09-16-2010 06:39 PM
Just to be clear, you guys are talking about losing the 2X6 entirely, right? And running a 2X4 on edge near the outer wall, with appropriate angle cut off bottom so that top edge is level? (Actually, 1.5" inch should be enough to be able to lay the 2X4 flat). So the seatboard would sit on that 2X4 and the corner edge of the concrete sill (and braces, of course). Yeah, that sure sounds easier, cleaner. Would the window being slightly lower matter in daily use, do you think? There are no other features it has to line up with visually, but I made a desk slightly too tall, once, and it still doesn't feel quite right.
Willie T 09-16-2010 07:20 PM
1 Attachment(s)
This is my basic thought. Shim it up however else you may need.
Tom Struble 09-16-2010 09:25 PM
all the bay units i see made today use a cable support system
oh'mike 09-16-2010 09:40 PM
The cable support holds the weight from above--
