Should This Pass Code? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-23-2011, 10:18 PM   #1
Rewards Points: 172
Should this pass code?
That's as close as I was comfortable framing to the electrical box. But the drywall will go right up to it so the cover will go over the drywall.
Should this pass code?-dscn0182.jpg   Should this pass code?-dscn0184.jpg   Should this pass code?-dscn0185.jpg
nateshirk is offline   Reply With Quote
Old 03-23-2011, 10:35 PM   #2
Experienced
Jackofall1's Avatar
Hi and welcome Nate, to the best DIY'r site on the web.
Don't see why that would not pass code.
Mark
Old 03-24-2011, 06:43 AM   #3
The only thing you may want to look into is where you notched for the wires to use a firestop expanding foam. i had to use some sort of fire stop foam or caulk for all my electrical holes through top plates.
baum is offline   Reply With Quote
Old 03-24-2011, 08:34 AM   #4
Rewards Points: 5,336
That's a very large panel with very few wires. You might want to build a removeable access panel to allow for further wiring.
Since most of the holes into the panel are on the sides and bottom, make sure you can work with the space you've allowed. You've blocked all the holes on the bottom.
Ron
Old 03-24-2011, 05:47 PM   #5
Rewards Points: 172
Ron
Good point Ron. The only other wiring I plan to add is for the basement, and maybe a 20 amp to the garage for the freezer. I guess I could just go out the side of the panel at this point. And I think there's more wires than you can see in the pic. Most were double stacked before being stapled. But yes very large. They used only a little over half of it.
Old 03-28-2011, 10:31 AM   #6
Rewards Points: 1,697
I realize it's already done now so anything other than meeting code at this point might be moot but why not just surface mount the panel? Or put it between two normally spaced studs? Most flush mount panels are designed to go between two studs.
dalepres is offline   Reply With Quote
Old 03-28-2011, 01:34 PM   #7
Because if you surface mount the panel the wire has to come out of the wall to get into the box. A code violation.
If you mount it between 2 studs, you block the side holes to mount the wires.
Ron
Old 03-28-2011, 08:06 PM   #8
Ron
So what is it that allows panels to be surface mounted? I see it all the time in pictures. It's pretty commonly done, isn't it?
Bryant Plus 90 Code 31 ~kirkland~ HVAC 1 03-08-2011 06:14 PM
question about code chrissy2008 Electrical 14 02-01-2009 09:48 PM
couple of code questions ponch37300 Electrical 9 01-26-2009 10:45 AM
Distance between Heater & Combustibles DIY_JC Building & Construction 7 01-20-2009 07:52 AM
Adding Kitchen pass through to an existing opening? sscott0203 Remodeling 7 12-13-2008 03:17 AM
