Old 07-29-2009, 02:01 PM   #16
Should I use drylock on my basement walls?
Do your self a favor and place a 12" x 12" piece of plastic on the basement floor, duct tape it good all the way around and check it for condensation in 24-48 hours. If ya find moisture after that test, take a step back from your project for a moment! Remember there's no need to piss up a rope! And there's no need for a basement to smell like a stinky stanky wet nasty sock sitting since sat began either! Try to remove gobbed up construction adhesive off the walls that some onionhead slapped on the wall just to keep some cheap styrofoam tacked up so he could blindly nail the whole basement with pretty plywood! Oh did I forget to mention a sheet of poly....nope! This prior homeowner not only busted his ass finishing the basement but probably couldn't quite figure out why the stinky stank even stunk! And I still have one more wall caked with adhesive to tackle! The real trick is getting the waterproofing the adhere in those areas after all is said and done! I'll have over 20 gallons of waterproofing on my walls, and 8 gallons of 2-part Sierra polyacrylamide slapped on my floor. The funny thing is I'm too freaking stubborn and flat out refuse to fire up my kick-ass homebrew system I bought for 6 grand over 3years ago until I get off my dead ass and finish the floor! There! So take a small step back from your project and do a simple moisture test on the floor! That little corner can be fixed and waterproofed in no time with a 41/2" disc grinder and a good ol' superdeluxe fat rope wire disc, a smidge of sulfamic acid dash of bleach and a splash of alcohol....
woobiken is offline   Reply With Quote
More On This Topic
Hi! This is Steven from Keilholz Flooring on behalf of Expertvillage.com and now I am going to show you how to put the material back into the adhesive. You are going to start up by rolling the material slowly back into the adhesive. Making sure to try... Read More »
Hi! This is Steven Keilholz Flooring on behalf of Expertvillage.com and this is our final stage of this flooring. And what we are going to do now is we are going to roll this flooring in making sure that they get completely seated into the adhesive. We... Read More »
Hi! This is Steven from Keilholz Flooring on behalf of Expertvillage.com. In this segment, I am going to show you how the apply the adhesive for your new floor installation in your basement. The first thing I want to do is because I am working in a small... Read More »
Newer, more energy efficient homes have been constructed to seal out the outdoor environment almost 100 percent. This condition allows loaded, stale air to accumulate unless windows are opened. Open windows allow some of the heating or air conditioning... Read More »
I'm James Donnelly for Expert Village and today I am going to show you what you might need in case of a flood emergency. Do not cross a stream or pool unless you are certain that the water is not above your knees and all the way across. Sometimes the... Read More »
insulating basement walls partially below grade fixrite General Discussion 8 03-06-2009 08:38 PM
Installing insulation and vapor barrier to exterior basement walls Fernando Sinn Building & Construction 11 04-11-2008 12:11 PM
Cracks in basement cemet walls avalon General Discussion 3 08-21-2007 06:28 PM
"floating" basement walls? greg s Carpentry 2 03-04-2005 08:56 PM
Running Conduit in new basement framed walls tben Electrical 3 12-11-2004 12:14 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
