Old 07-27-2009, 12:15 PM   #1
Default Should I use drylock on my basement walls?
Im trying to decide if I should water proof the basement walls and floor? I do not have any major water issues. The only thing I have is a small saturation point where a wall meets the floor. No water build up or puddling at all. This moisture point has only happend twice. The previous homeowner had water issues due to poor grading and a beat down gutter system. I have since currected those issues and the basement has not seen any water, besides what I mentioned above in over 3 years.
Any feedback would be appreciated.
Thanks.
Leoskee is offline   Reply With Quote
Old 07-27-2009, 07:22 PM   #2
long island, NY
first off, I'm jealous you regrated your yard and have a dry basement! This is on the top of our "to do" list, but will be too $$$ for us until next year (must also demo/replace a large patio, and put up a small retaining wall to accomplish this goal). But I digress....
Why drylock something that really is fine? It's a lot of work, and not very pretty. 25 years ago, our basement was waterproofed with some (much earlier generation) drylock-like material... and it actually came off of the wall due to water coming through the window... now the wall under the window is a total mess.
diy'er on LI is offline   Reply With Quote
Old 07-27-2009, 07:49 PM   #3
I have something similar on my walls. It looks like they painted the cement and it flaked off during the years. I would have to scrape all of this stuff off of the wall before I use the drylok. My main reason for wanting to do it is because once the remodeling work is done I will not have the opportunity to. If it helps keep things dry I would go through the trouble.
The reason that I am asking is because I have heard mixed reviews and wanted to get some more feedback from people that have used it or are familiar with the product.
Old 07-28-2009, 01:21 AM   #4
If waterproofing, do it to the outside walls, not inside. Read this on moisture in the basement, and the solution:
http://www.buildingscience.com/docum...gs?full_view=1
Be safe, G
GBR in WA is offline   Reply With Quote
Old 07-28-2009, 10:40 AM   #5
If you don't have major water infiltration it would help, at the very least, the humidity level in your basement. ALL basements are going to be a little more humid than the rest of the house. You could lower this a bit by using dryloc.
Oh, and don't do the floor unless you plan on covering it with finish flooring or something else. Drylock is not rated for horizontal surfaces the get foot traffic.
cibula11 is offline   Reply With Quote
Old 07-28-2009, 01:43 PM   #6
long island, NY
ugh, so you're in the same boat as us... that's a big job to scrae all of that If you're going to finish the basement, you might as well do everything you can.... either drylock or another product someone might recommend here....
Old 07-28-2009, 06:55 PM   #7
ALL basements leak because water rush's to fill a void & soil acids have yrs to attack foundations,,, speaking of boat, think of your bsmt as a ship's hull below the waterline,,, we're not meant to live in bsmts, either,,, UNLESS your home's blt by a few hi-end outfits, look for problems down the road.
cmu block walls're ESPECIALLY subject to leakage,,, decent conc fnd walls're MUCH easier to repair - otherwise, its the french drain approach,,, i have drilok-something ) on my bsmt wall - it still leaks, looks horrible, & grows mold but we live upstairs,,, i need to practice what i preach, too since i did this work professionally in ny-nj-ct, it'll get done the right way before damage when we sell,,, waterproofing a bsmt is impossible UNLESS you excavate the total wall perimeter,,, otherwise you only manage the problem !
itsreallyconc is offline   Reply With Quote
Old 07-28-2009, 07:36 PM   #8
So I'm not alone out there? Well I surface prepped the Hell out of the walls making sure no salt formations exist as well as any cracks, etc. Then I used the oil based UGL product "THICK" on the walls....Twice!!! Only one corner needed an extra spanking due to salt formations. My basement floor is currently undergoing an industrial epoxy coating but in the end it will be just fine for me. I'm fortunate with sand all around the house making hydraulic issues minimal at most. But the walls have looked great for 5 years or more and way less humidity so I may not have to run the dehumidifier once my floor is done!
woobiken is offline   Reply With Quote
Old 07-28-2009, 07:59 PM   #9
cmu block walls're ESPECIALLY subject to leakage>>>>>>>>>>>>>>>>>>>>>........
No more than any other material if the proper precautions are followed on the outside.
Read the whole post now, you should know better. A cmu wall is fine and you know it if the waterproofing is done on the outside!!
framer53 is offline   Reply With Quote
Old 07-28-2009, 09:22 PM   #10
I have a poured concrete foundation. Im going to go ahead and use drylok on the walls. Would it be worth the trouble of using it on the concrete slab?
Old 07-28-2009, 09:38 PM   #11
Not to be used where you walk, and since you walk on the slab, it is not to bew used>.
Old 07-28-2009, 10:34 PM   #12
What can be used on the floor. Woobiken mentioned an industrial epoxy coating.
Old 07-28-2009, 11:45 PM   #13
I take it back!!! I will not, and I repeat, NOT be using drylok on my basement walls. I just spent the last hour trying to clean off all of the crap that is on a 3x7 portion of a wall and I feel like I didnt even make a dent. First I used a deck brush to scrape off as much stuff as I could. Then I used a paint stripper wheel attached to my drill. My arms are killing me. I too a break towards the end and looked at how much more square footage I had to do that I decided right there that it was not worth it. Like I stated before, I do not have any major issues in my basement anymore. If I am going to frame the walls and cover them in sheetrock why do all of the work if no one will see the walls?!
Thanks for all of the input and comments. I'll keep posting questions as I go along with the project. As a matter of fact I am going to take some pics right now to document my project and create a thread.
Old 07-29-2009, 01:27 AM   #14
if its tight, don't worry,,, the fail'd stuff falls off soon enough by itself,,, sand soil's good for drainage but framer's got 'canisteo loam' for the most part,,, MUCH different stuf,,, cmu's are fine BUT the waterproofing's done OUTSIDE before backfilling,,, the building code's specs suck & are minimal therefore of no use,,, bldrs offer a 1yr warranty on bsmt leakage knowing it takes longer to show up
do a moisture test 'fore investing in wood 2x4's & drywall & screws & jnt compound & labor
Old 07-29-2009, 01:31 AM   #15
Im putting down a dricore subfloor w/ PT wood as the base plate. Using regular 2x4 for top plate. I spent the extra $ and will be using purple board (moisture resistant sheetrock) along the perimeter of the basement and also in the bathroom. The rest will be in regular 1/2" sheetrock.
More On This Topic
Hi, I'm Jeremy Blackwell, I'm here today to help you get started on your basement remodel project. Remodeling a basement can be a big task. When you want to remodel your basement, you first want to think about how big it is and what you want to do, with... Read More »
Hi, I'm Jeremy Blackwell. I'm here today to help you get started on your basement remodel project. Some of the common things you want to watch for in framing, is to make sure that all of your walls are plum, level and square. This keeps everything... Read More »
Right now I started a project. When I first started it had all the ceiling, the whole ceiling was taking down. So I had to put tracks so I can put the new ceiling up. I'm trying to sound proof it so when they record down here. I build the booth so when... Read More »
Hi I'm Jeremy Blackwell, I'm here today to help you get started on your basement remodel project. When framing the basement, we try to find the longest wall possible and square from that wall on. In this basement, this would be that wall. This is a great... Read More »
Hi, I'm Jeremy Blackwell. I'm here today to help you get started on your basement remodel project. The schedule that you'll use when finishing a basement is very similar to the schedule that you'll use when finishing a home. In fact, it's almost exactly... Read More »
insulating basement walls partially below grade fixrite General Discussion 8 03-06-2009 09:38 PM
Installing insulation and vapor barrier to exterior basement walls Fernando Sinn Building & Construction 11 04-11-2008 01:11 PM
Cracks in basement cemet walls avalon General Discussion 3 08-21-2007 07:28 PM
"floating" basement walls? greg s Carpentry 2 03-04-2005 09:56 PM
Running Conduit in new basement framed walls tben Electrical 3 12-11-2004 01:14 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
