Should I Use 2x8 Or 2x10 For Deck Construction? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-15-2011, 09:29 AM   #1
Should I use 2x8 or 2x10 for deck construction?
Hey guys,
I am going to start building my deck and have done several designs online. My deck will be 16 x 16 attached to the house (2x12 ledger board). The online design program I am using has 8 footings to be poured (2 are for the stairs). My question is can I use 2x10s instead of 2x8s and get rid of 3 footings (or should I stay with the original design? I will have to move my stair footings closer to the house to support where the stairs come down ( 5 footings instead of 8?). Thanks for any info provided!
Should I use 2x8 or 2x10 for deck construction?-deck.jpg   Should I use 2x8 or 2x10 for deck construction?-deck2.jpg
danreg99 is offline   Reply With Quote
Old 04-15-2011, 09:44 AM   #2
Rewards Points: 2,238
From your pictures (don't know the exact scale or dimensions) -
between the beam on the left, and how far the cantilever past that beam is -
the length of the cantilevered joists is too long.
It looks like 3 feet or longer.
If you're talking about using 2 X 8's or 2 X 10's for your beams - 2 X 10's.
Others will add some input.
rossfingal
rossfingal is offline   Reply With Quote
Old 04-15-2011, 09:53 AM   #3
kwikfishron's Avatar
Rewards Points: 430
Pretty sure that’s where the house goes.
kwikfishron is offline   Reply With Quote
Old 04-15-2011, 09:55 AM   #4
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,346
With 2x10 joists 16 OC the max span is 13'7" so if you put the beam at 13' you would have 3' over cantilever. it works according to the the residential deck guide.
With that said, I'd go 2x8 as you have illustrated with a beam in the middle. It will be stiffer.
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 04-15-2011, 09:59 AM   #5
Oops! Thanks!
RF
Old 04-15-2011, 10:54 AM   #6
Rewards Points: 5,336
I agree with Clutch. They'll be too much bounce with 2x10's and only one set of supports.
Ron
Old 04-15-2011, 11:31 AM   #7
Thanks guys! I guess I will just have a little more digging to do
Old 04-15-2011, 05:48 PM   #8
Not so new
12penny's Avatar
Rewards Points: 520
Really?....I do 13', 2x10 spans all the time and have never had a complaint that the floor was too "bouncy". As I see it he only needs support to carry the landing at the top of the stairs.
Enlighten me.
12penny is offline   Reply With Quote
Old 04-15-2011, 08:09 PM   #9
In a little over my head
Rewards Points: 706
Rent a power auger for the digging. You won't care how many you need to dig. Best $40 I spent when I built my deck.
ratherbefishing is offline   Reply With Quote
Old 04-16-2011, 06:47 AM   #10
Not so new
12penny's Avatar
Rewards Points: 520
...after sleeping on it, I feel I should clarify my earlier reponse.
While 2x10's spanned 13' are within allowable tolerances there is no question that they'll have more bounce than 2x8's with half the span.
Considering the top of the stairs need to be supported, it does make sense to run that support all the way accross to halve the span.
Next time I need to think a lttle more before I blow out a response.
Old 04-16-2011, 11:49 PM   #11
Registered User
Rewards Points: 5,498
Dan, this may help you; http://www.lancova.com/deckinfo.pdf
'09 update; http://www.awc.org/Publications/DCA/...eckarticle.pdf
At least change the beams drawn. Too fuzzy to see the rest, or too old....
Gary
Old 04-17-2011, 08:53 AM   #12
[quote=12penny;630368
Next time I need to think a lttle more before I blow out a response.[/quote]
Oh man, does that mean we all have to do that now?
Maybe I should retink this post then?
Ron
Old 04-17-2011, 09:35 AM   #13
Not so new
12penny's Avatar
Rewards Points: 520
lol..
Soft Hearted Construction Guys Wildie Building & Construction 0 11-29-2010 06:05 PM
Gable dormer construction questions Joe1. Building & Construction 21 08-01-2010 10:17 PM
Need advice on low-to-ground deck construction... DaveNJ Building & Construction 8 11-09-2009 04:21 AM
tripple 2x10 beam construction george514 Building & Construction 5 05-29-2007 03:09 PM
