Should I Sister Block - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-30-2013, 05:27 PM   #1
Should I sister block
I don’t need to backfill the area prior to jacking up the floor. A few shoring jacks some lumber and wah-la. I can skip that question. Now the topic is, the kitchen of this house is supported on one side by a concrete knee wall topped with a sill plate and the other side has a ledger board attached to the basement wall with 5/16 wedge anchors, on 30” centers staggered over the length of the board. There are joists 16” OC spanning 12’ on top of the sill and ledger board. There is a rim joist nailed to the floor joists at the knee wall end but there isn’t any blocking at the ledger end for the joists. Additionally, at the point where two sections of ledger board meet the builder cut a 40” opening in the basement wall for plumbing HVAC, etc. Since then the ledger has sagged because of the floor load at that point. I want to repair the structure.
If I sister the ledger board span issue created by the opening in the basement wall and install additional supports such as angle iron on either side of the sistered joint maybe attach the angle iron with 3/8” x 3 cement anchors—would this be enough to support the floor above?
If I add solid blocking to the joists at the ledger board end of the span would this satisfy code and prevent joist rotation?
Should I install more anchors into the existing ledger board?
ToolMonger is offline   Reply With Quote
Old 01-30-2013, 07:24 PM   #2
Rewards Points: 12,808
Long confusing post that may be cleared up with a simple picture.
How to face a cinder block retaining wall with stone? CarrollY Concrete, Stone & Masonry 5 09-04-2012 01:26 PM
Concrete (Cinder) Block Barebones Home : Seeking Advice granadaCoder Building & Construction 11 08-11-2012 08:03 AM
Vertical Rebar Layout in Block Wall Footing 99altrade Building & Construction 6 08-12-2011 10:32 PM
Widening gap - notch sister joist or cinder block? John_W Building & Construction 6 06-29-2011 09:37 AM
Fire blocking a wood stud wall built against cinder block. BasementVirgin Building & Construction 1 10-06-2009 12:02 AM
