Should I Seal Where Wood Trim Meets The Brick? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-01-2008, 12:23 PM   #1
Should I seal where wood trim meets the brick?
New homeowner here, so pardon my ignorance!
I was out doing some yardwork the other day and I noticed a wasp go between the wood trim (that is under my eaves) and the brick (that makes up the exterior wall of my house). I was just wondering if I should seal that somehow or is there meant to be a small gap for ventilation?
If I should seal it, what product do you guys recommend? A foam or a caulk?
megan81 is offline   Reply With Quote
Old 07-01-2008, 12:40 PM   #2
Registered User
Termite's Avatar
The wood trim on the exterior wall of the house under the soffits is called a frieze board. Assuming there's a soffit over it, it probably isn't flashed in any way because it won't get direct water running off it. So, I don't see any reason you can't caulk it to seal it up. I would not suggest spray foam for this...Too hard to control when it expands. For small gaps, exterior caulk will work fine. If the gaps get a little larger, you can use foam backer rod in the gap and caulk over the backer rod.
Tile with a wood trim? trick29392 Flooring 3 06-26-2008 07:19 AM
Exterior trim paint is peeling, wood is rotting! firsthomenewb Painting 10 05-15-2008 05:04 PM
Which paint to use? Painting wood trim white Proulx06 Painting 11 04-09-2008 08:18 PM
Brick and wood flooring jhughesfam Flooring 1 08-18-2007 03:29 PM
Seal Cat Smell On Brick flyingzs Flooring 5 08-09-2007 01:20 PM
