-   -   Should I seal where wood trim meets the brick? (http://www.diychatroom.com/f19/should-i-seal-where-wood-trim-meets-brick-23052/)
megan81 07-01-2008 12:23 PM
New homeowner here, so pardon my ignorance!
I was out doing some yardwork the other day and I noticed a wasp go between the wood trim (that is under my eaves) and the brick (that makes up the exterior wall of my house). I was just wondering if I should seal that somehow or is there meant to be a small gap for ventilation?
If I should seal it, what product do you guys recommend? A foam or a caulk?
Thanks!
Megan :wink:
Termite 07-01-2008 12:40 PM
The wood trim on the exterior wall of the house under the soffits is called a frieze board. Assuming there's a soffit over it, it probably isn't flashed in any way because it won't get direct water running off it. So, I don't see any reason you can't caulk it to seal it up. I would not suggest spray foam for this...Too hard to control when it expands. For small gaps, exterior caulk will work fine. If the gaps get a little larger, you can use foam backer rod in the gap and caulk over the backer rod.
