Should I Replace The Sub-subfloor? Pix Attached - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-21-2008, 03:47 PM   #1
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,284
Should I replace the sub-subfloor? Pix Attached
I'm going to be tiling my foyer. I pulled up the existing hardwood floor to add another layer of 3/4" plywood subfloor and the existing subfloor looks like there are a lot of voids. I'm wondering if I should remove the existing subfloor and then add 2 layers of plywood instead of just one layer over the existing plank subfloor. What do you think?
TIA
Cliff
Should I replace the sub-subfloor? Pix Attached-subfloor2.jpg   Should I replace the sub-subfloor? Pix Attached-subfloor.jpg
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 01-21-2008, 04:18 PM   #2
I dont really see any point into ripping out this subfloor if you are planing on putting another subfloor on top of it. You can just put the 3/4 on top of the pre-existing floor that is there. Replaceing the the pre-existing subfloor will cost you more. So to save some money just put the 3/4 on top of it. the only suggestion that i can give you is to make sure the joints on the 4ft side of the 3/4 is on a joist that will help with support. If you do that you wont have to worry about the 3/4 being on a part of the weak flooring.
http://pshomehelp.com
PSHome is offline   Reply With Quote
Old 01-21-2008, 06:53 PM   #3
Master General ReEngineer
Bondo's Avatar
Rewards Points: 334
Ayuh,..... I Agree, No reason to rip it up for nothing......
Well Mark where the joists are,+ Put the Screws to it...........
More Screws,......... Less Squeaks.........
Old 01-21-2008, 07:14 PM   #4
I have gas!
I spoke with the folks at the tile store and they said the subfloor should be 1 1/2" thick. I guess I'm thinking, how much can the existing subfloor contribute to stiffening up the floor when there are all these holes and gaps?
Old 01-21-2008, 07:26 PM   #5
Bondo's Avatar
Rewards Points: 334
Ayuh,......... Alot........
There's Still Strength thru Structure there......
The Gaps,+ Especially the Holes are pretty much Irrevelant..........
Are you putting Cement board over the Plywood,..??....
Old 01-21-2008, 08:34 PM   #6
I have gas!
I'll be using Ditra instead of a cement backer board.
Old 01-21-2008, 11:40 PM   #7
the second layer of subfloor will spread the load of the tile out enough they want you to put two layers of subfloor for support of the tile. you will never have enough forec on one of the cracks or holes to do anything and it it can support it the 3/4 will support it. http://pshomehelp.com
Old 01-22-2008, 07:49 AM   #8
I have gas!
Thanks, I'll leave the existing planks. Should I run the plywood perpendicular to the joists or planks?
Old 01-22-2008, 08:32 AM   #9
Woodworker and Contractor
Kingfisher's Avatar
Rewards Points: 150
Add some insulation LOL
Kingfisher is offline   Reply With Quote
Old 01-22-2008, 09:42 AM   #10
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Yes, use liquid flooring adhesives (subfloor adhesive - PL/liquid nail)-along with your fasteners (nails/screws).
Make sure that you go over any boards and re-nail the loose ones prior to installing the plywood...
- Build Well -
Old 01-22-2008, 10:20 AM   #11
I have gas!
Two more questions, what type of plywood should I use, CDX, T&G,...? I should be using 3" screws, right?
Old 01-22-2008, 11:57 AM   #12
The type of sub flooring is up to you, and your budget. You always want to go with a tounge and groove sub floor. I dont personally like Advantech T&G its easy to work with, lays flat and is easy to install the tounge and groove. thats just what i noticed when using it. I would use 3 inch screws
Old 01-22-2008, 02:41 PM   #13
Rewards Points: 1,910
Have you checked to see if the floor joists are adequate for tile? It looks like what you have are 2x8 at most (maybe even 2x6). Check the size and span to be sure they will give you a stiff enough floor. If they need beefing up now would be the time to do it.
Old 01-22-2008, 04:07 PM   #14
I have gas!
Thanks for thinking ahead. Yes, I covered that in a previous thread. You're correct, there are only 2x8s with a 12' span on 16s. I'll be sistering the 2x8s to stiffen the floor assembly.
Old 01-22-2008, 05:53 PM   #15
....Are you saying that you don't like AdvanTech Flooring?....By what you wrote, it sounds like you do.
We prefer it, and so do just about every contractor I know...
- Build Well -
Should I replace all of the plumbing? Pics enclosed? twilightcall Plumbing 15 01-23-2008 09:50 AM
Replace main panel? And lots of other ?s Bcoleman6 Electrical 13 01-22-2008 10:40 AM
Removed ceiling fan, trying to replace w/light fixture-need help Mikedks Electrical 10 09-22-2006 03:00 PM
