Should I Pour A Cement Base For A New Tub? - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-13-2009, 08:41 PM   #16
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 132
I'd be concerned about how heavy that much cement would be, especially when adding a tub full of water to that load!
Not sure if this is the right way of doing it but I noticed in my house the old tub is sitting on some kind of foam form.
Adding support mostly all around the tub sounds like a better way to support it though that way the weight is better distributed.
Old 08-13-2009, 09:12 PM   #17
Old School
Willie T's Avatar
The concrete weighs about the same as one leg of an adult male. And if weight is a big concern, "lightweight" concrete would help a lot there.
Willie T
Old 08-13-2009, 09:38 PM   #18
Registered User
Rewards Points: 526
He is on a concrete slab......
Wouldn't you fill the 6" with concrete block, then the concrete mounds? The bottom of the tub is elevated 6" for the P-trap. Willie T- have you ever used a bucket of tapping mud for a set on wood floors, tar paper first? Be safe, G
Old 08-13-2009, 10:13 PM   #19
Old School
Willie T's Avatar
Yeah, on a concrete slab, I'd probably use pavers or partition blocks laid on their sides to bring the base up high enough to only need a couple of inches of concrete (or mortar).
And No, I've never tried DW mud, but it sounds easy.. and only about $11. Sharp idea.
Willie T
Old 08-13-2009, 10:29 PM   #20
Rewards Points: 174
No offence taken. At least not after you explained where you were coming from.lol. I guess I would feel the same if I saw someone start several questionable posts. But my situation is real. I am not a pro so I am learning every day from the web, from books and from asking questions. All of this made my wife tell me that she was very impressed with the work that I had done so far in the basement. She was so impressed that she confessed that she had already calculated into our monthly budget getting someone to complete the project I am in the process of doing because she did not think I could do it.
Leoskee is offline   Reply With Quote
Old 08-14-2009, 05:00 AM   #21
the Musigician
DangerMouse's Avatar
i knew you were for real, i looked at your post #s.
trolls don't have 75 posts here, normally! lol
DM
Old 08-14-2009, 05:02 AM   #22
the Musigician
Originally Posted by Willie T View Post
Hint: If you want to be able to remove the tub sometime after setting it into the cement, lay a sheet of Visqueen atop the wet cement columns before you ease the tub down on top of them.
good one willie! i'll have to try to remember that when i set my new tub next summer!
tnkx!
DM
Old 08-14-2009, 08:12 AM   #23
Rewards Points: 174
I thought that I posted this question yesterday but I do not see it. Anyway, what are the dimensions of cinder blocks? Could I use them to put the wet stack on?
Old 08-14-2009, 08:28 AM   #24
the Musigician
cinder blocks are supposed to be 8"x8"x16", however, actual size seems to be a bit smaller...7-5/8"x15-1/2ish on the ones i just measured out front.
DM
Old 08-14-2009, 08:50 AM   #25
47_47's Avatar
Rewards Points: 62
DM
The blocks are smaller because when you add the mortar joints, they are the 8"x 16".
47_47 is offline   Reply With Quote
Old 08-14-2009, 09:08 AM   #26
Old School
Willie T's Avatar
This is a "cheater", but there are actually wiggly little strips of metal you can buy (haven't seen them for years) that are 3/8" wide. They are spacers you set into the mortar to automatically give you 3/8" (standard) joints. Pros never use them, so they may be difficult to find.
Willie T
Old 08-14-2009, 09:16 AM   #27
the Musigician
4747: d-oh! that would make sense, yup....
DM
Old 08-14-2009, 09:54 AM   #28
47_47's Avatar
Rewards Points: 62
DM, That's one of those things that you take for granted and don't think about. If you were to ask my home phone number, I wouldn't know it, but I could dial it.
Old 08-14-2009, 10:08 AM   #29
the Musigician
yeah, but i shoulda thunka that too, silly me.
DM
Old 08-14-2009, 12:06 PM   #30
Rewards Points: 174
I just came back from Lowes. They had standard blocks and then "gray" blocks. The gray blocks were much larger. I didnt measure but I think they are 6" tall. If thats the case it would be perfect for my project. I'll go back and measure later on.
box mounting b4 cement pour jambud Electrical 1 08-13-2009 12:45 PM
cement wet after pour zantar Building & Construction 5 06-24-2009 05:04 PM
Rotten cement - skim coat or board? BradG Building & Construction 1 11-25-2007 02:25 PM
Outdoor hot tub...Is pouring cement base a diy project? Bacardi 151 Building & Construction 4 05-12-2007 11:04 AM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 01:07 PM
