Should I insulate Walls and Ceilings or not?
I have been remodeling a bedroom, and have to decide whether to put in insulation in the walls and ceilings so I will try to tell you in detail the climate conditions of where I live so that you can get a good idea of what my insulation needs are.
1. I live in Hawaii so in the summer time it is humid and hot(although not as hot as alot of the other states during the summer) and during winter it gets chilly(coldest is 50-55 degrees F. which is cold for me).
2. I live in a two story house with the bedroom being remodeled on the first floor.
3. The Lower floor seems to be hotter than the upper floor(there is no insulation at all anywhere in my house.)
4. I will have a computer in this room that will run almost 24/7.
5. I do plan on installing either a window a/c or a portable a/c to run for a few hours after i get home from work.
My ceilings are 2x8 joists and the walls are 2x4 studs. My main goal is to cool down the room during the summer since i am roasting. Should I insulate the walls and ceilings or would insulation basically just compound the problem? I am leaning towards insulating the ceiling for soundproofing, but there will be a drop down ceiling and I might possibly use quietrock drywall as the ceiling tiles which would really soundproof the room. Any help/suggestions would be much appreciated.
