Should I Insulate This? (pic) - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-27-2010, 07:40 AM   #1
Should I insulate this? (pic)
See pic attached. I have a cape cod. My father insists I should extend the vent cutes all the way to the soffit and insulate the roof all the way to the soffits so the "Storage area" doesn't blow cold air into the main room. I'm concerned about cutting off airflow/creating mold. Suggestions?
chazman113 is offline   Reply With Quote
Old 07-27-2010, 09:05 AM   #2
I have the same setup, mine is storage also
Everything is insulated & I ran the rafter vent to the soffit
Also sheetrock installed
The warmer the storage area, the warmer the room
The Following User Says Thank You to Scuba_Dave For This Useful Post:
chazman113 (07-27-2010)
Old 07-27-2010, 09:24 AM   #3
Cool, how did you deal with the part of the insulation where the roof meets the floor, just staple it to the corner? Any mildue issues near the soffitt and the insulation?
Old 07-27-2010, 08:00 PM   #4
Registered User
Rewards Points: 526
"I'm concerned about cutting off airflow/creating mold. Suggestions?" Unless the storage area is heated or at least the same temperature as the room, the moisture will condense on the insulation being colder due to the incoming air above. OR, the best way is to insulate the walls of the room/attic and install some house wrap to prevent the attic air from wind-washing the exposed wall insulation. If you read all baffle instructions, it says leave a 1" gap between ends for removal of trapped moisture: http://www.adoproducts.com/duro.html
.Air seal the attic space from all heated areas: http://www.rd.com/how-to-seal-attic-...icle18158.html
Sealing the joist bays and attic door: http://www.simplesavings.coop/simple...ee%20walls.pdf
If an older balloon framed house: http://www.wag-aic.org/1999/WAG_99_baker.pdf
This should keep you busy until Dave answers your question.
Be safe, Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
Tags
insulation , mold , roof
Insulate basement header with imbedded joists??? lackofunds General DIY Discussions 21 04-17-2011 03:41 PM
How to Insulate behind Wall Stack Supply Duct whirly HVAC 5 03-08-2010 04:47 PM
do I need to frame my basement insulate with batt insulation? y2chuck Remodeling 3 02-15-2010 08:13 AM
How to insulate attic crawl space RISurfer Building & Construction 7 10-01-2009 11:57 AM
Insulate or Don't Insulate? helpless handyman Building & Construction 10 03-31-2008 06:07 PM
