Old 10-21-2008, 08:07 AM   #1
Should I Furr Over 6" Of Block ??
See picture links below. Converting garage into family room.
On the one inside wall, framer had to leave 6 inches of concrete block at the bottom of the wall. The block sticks out ~1/4 inch past the 2x4.
Framer doesn't think furring strips are needed. He says drywall can be attached over top this 6 inches of block.
I need to know your opinion. Should I install furring strips from floor to ceiling, or can I attach the drywall over the block? Is the extra 1/4 inch of block going to be a problem?
http://i182.photobucket.com/albums/x...s/IMG_2971.jpg
http://i182.photobucket.com/albums/x...s/IMG_2970.jpg
http://i182.photobucket.com/albums/x...s/IMG_2969.jpg
wrldruler is offline   Reply With Quote
Old 10-21-2008, 10:24 AM   #2
Moderator
Termite's Avatar
I'd fur it out. You need attachment for your sheetrock at the bottom. It could be glued, but I think touching rock to masonry or concrete is a bad idea.
Besides, what else are you going to fasten the baseboard to? You need some wood in there to facilitate that!
Brick Ledge when using cinder block DaveMo Building & Construction 5 07-13-2011 10:46 AM
Cracks In Block Wall Foundation vf100 Building & Construction 7 08-20-2008 10:48 PM
Cutting cinder block for a large door opening joeyb Building & Construction 2 02-10-2008 01:00 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 05:08 PM
