Should I Float A Footer For A Block Wall? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-27-2010, 06:44 PM   #1
Should I float a footer for a block wall?
Or screed only so the mortar will have more to grab?
walkman is offline   Reply With Quote
Old 02-27-2010, 06:47 PM   #2
we use to finish by tamping a rake down on the surface
The older I get the better I was
Old 02-27-2010, 07:23 PM   #3
Never smooth, for a better grip, even add a keyway.
Old 02-27-2010, 09:45 PM   #4
concretemasonry's Avatar
Rewards Points: 2,566
Even better is to set the first course or two late the same day the footing is poured. If it rains over night you feel like a genius and make things much easier. That is why the real successful contractors are "Concrete and Masonry Contractors" so they are more efficient and control the scheduling. - It sure beats having to wait for Mother Nature to dump some rain on the job and make a mess and screw things up.
Dick
concretemasonry is offline   Reply With Quote
Old 02-28-2010, 06:26 PM   #5
Retaining Wall and Muddy Yard rjschwar Landscaping & Lawn Care 10 02-24-2010 01:55 PM
Fire blocking a wood stud wall built against cinder block. BasementVirgin Building & Construction 1 10-06-2009 12:02 AM
Building a cinder block wall. helpless handyman Building & Construction 5 04-29-2009 11:22 AM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 05:08 PM
