Should I Bolt My Tri-level House To The Foundation? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-16-2009, 03:00 PM   #1
Should I bolt my tri-level house to the foundation?
I have a tri-level house in the Seattle area, built in 1971. I don't believe it's bolted to the foundation. Half of the house (the side with two floors) sits on top of a slab. The other side of the house is on a standard foundation that I have easy access to, the storage space underneath has a 7' ceiling. I'm wondering if I should look into bolting the non-slab side of the house to the foundation? Or if the side of the house that sits on slab should be sufficient to hold the other side of the house on the foundation in the event of a big earthquake. Thanks for any help or advice!
SeattleDuck is offline   Reply With Quote
Old 10-16-2009, 04:10 PM   #2
Too Short? Cut it Again!
Anchoring the house to the foundation is a good idea. Most of the houses damaged in the last San Francisco earthquake had gone through extensive renovations but this important step was skipped. It is the reason many could not be saved. It is relatively inexpensive to do this.
Old 10-16-2009, 04:50 PM   #3
Home Remodeler
Rewards Points: 164
Default has some some great information on earthquake upgrading including DYI. Under comsumers. Here is the link
mikey48 is offline   Reply With Quote
Old House Rewire finnimus Electrical 15 05-13-2011 10:39 PM
I have Central Heating & Air, but house won't cool down..HELP!! exiledone1 HVAC 13 07-10-2009 10:09 PM
Unfused connectors MELTED House wires WHAT TO DO??? jamiedolan Electrical 63 02-12-2009 06:01 PM
Foundation drain and sump pump slatergrl Plumbing 3 02-10-2008 09:36 AM
