Short Closet Opening - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-24-2009, 10:21 PM   #1
Rewards Points: 123
Short Closet opening
I have a closet opening which is very small, about 67" tall by 30" wide. I would like to install a bifold door.
What options are available?
jerome8283 is offline   Reply With Quote
Old 11-25-2009, 06:10 AM   #2
You don't mean 6'7", correct?? It is actually 67"? The only type door you could cut down to fit, would be a flat panel door. Otherwise have custom doors made.
Old 11-25-2009, 08:30 AM   #3
Rewards Points: 123
No, 67". Thx
Old 11-25-2009, 11:53 AM   #4
Rewards Points: 1,910
If you can find a solid bifold door you could probably cut it down to fit.
Putting a wall over a large opening, need ideas aqzman Building & Construction 5 10-28-2009 03:46 PM
Installing closet doors into un-true opening - Need ideas McCool Carpentry 8 08-12-2009 01:37 PM
Closet Opening remodel-virgin Carpentry 2 06-13-2009 08:29 AM
Finishing opening for closet Frank_N_Stein Carpentry 11 12-24-2008 08:52 PM
Hardwood closet threshold question DIY-Renovator Flooring 1 07-27-2008 04:42 AM
