Shooting Treated Sill 2x4s Into Concrete - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-09-2008, 09:57 AM   #16
old concrete is much harder to get your nail shot into.I would glue the plate down,shoot nail with max. load,and move on.Never try to hammer the nail down further because chances are it will just loosen the nail.
johnrem is offline   Reply With Quote
Old 02-12-2008, 08:20 PM   #17
remodeling pro
Originally Posted by Cole View Post
Hammer?
Only if you want them to all fail. One lick to a powder set fastener to try to drive it home will shatter the concrete around it and make it useless. You can get away with it often on newly poured green concrete, but not once it has cured.
troubleseeker is offline   Reply With Quote
Old 02-12-2008, 08:29 PM   #18
remodeling pro
Originally Posted by amakarevic View Post
when i shoot 3-in coated nails w/out a washer to fasten pressure-treated sill 2x4s into concrete, is it normal to have the nail head stick above the 2x4 for about 0.25 in, i.e. the length of the orange fletching ? i.e. what sticks above is the nail head + the fletching.
thanks,
- a -
If attaching to cured concrete and are already using max powder charge, you may have to drill holes with rotary hammer and use split shank or deformed shank anchor pins, available at contractor suppliers. They look like a blunt, fat nail with an oversize head, and either have a "kink" in their shank, or a couple of protruding nibs punched into the shank. Best driven with a three or four lb hammer, and hope you don't have to remove them.
Old 02-13-2008, 09:54 PM   #19
Extreme DIY'r Adk's, NY
Rewards Points: 272
I use 2-1/2's also on cured concrete. After all...It's in concrete and will only see sheer loads on most apps anyway.
crecore is offline   Reply With Quote
Pressure treated posts set in concrete? zubin6220 Building & Construction 19 08-13-2013 05:39 AM
shooting nails through 2x4s into concrete amakarevic Building & Construction 6 01-28-2008 09:52 PM
new concrete floor next to old concrete floor mattroos Building & Construction 10 08-28-2007 01:32 PM
Aluminum Door sill and Concrete Dragon Building & Construction 2 01-06-2007 12:55 PM
Need to expand existing concrete pad for A/C unit miketegra Building & Construction 2 07-03-2005 10:27 PM
