Shooting Treated Sill 2x4s Into Concrete - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-05-2008, 02:11 PM   #1
Rewards Points: 1,062
Question
shooting treated sill 2x4s into concrete
when i shoot 3-in coated nails w/out a washer to fasten pressure-treated sill 2x4s into concrete, is it normal to have the nail head stick above the 2x4 for about 0.25 in, i.e. the length of the orange fletching ? i.e. what sticks above is the nail head + the fletching.
thanks,
- a -
Old 02-05-2008, 02:29 PM   #2
PRO Siding Windows Roofs
bigger ammo
PKHI is offline   Reply With Quote
Old 02-05-2008, 02:33 PM   #3
I agree with PKHI. I've had the same thing happen to me. I've shot the nails in the concrete in my basement and it did fine. I went to help a friend out and had to go to a stronger blank.
Chops is offline   Reply With Quote
Old 02-05-2008, 05:11 PM   #4
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Upgrade the shot power (Firing caps).
- Build Well -
Old 02-05-2008, 05:20 PM   #5
Mod / ArchiBuilder
Cole's Avatar
Hammer?
Cole is offline   Reply With Quote
Old 02-05-2008, 11:00 PM   #6
but i think i am already using the strongest amo - no. 5.
Old 02-05-2008, 11:19 PM   #7
Question
also, when lubing my nail gun, should i use the same oil as is used for ... well ... regular guns ?
Old 02-06-2008, 08:06 AM   #8
Yes.
What you want to use is: Gun Cleaner, and gun Oil.
I suggest that you simply use the combined solutions (cleaner and lubricant). Walmart sells small bottles of different solutions.
Clean the fastener after every use.
The reason being that you are using powder actuated caps that produce carbon powder residue (like in firearms). That powder, if not cleaned, will damage and jamb up the operating function of the tool.
We keep a small sprizter bottle and rags in each fastener's case.
- Build Well -
Old 02-07-2008, 02:26 PM   #9
Rewards Points: 31
Hammer won't work, you can't hit the nail hard enough and straight enough to make it sink into the concrete once it's already in there 90% of the way. I had the same problem, the max load yellow caps wouldn't quite drive the long nails fully into the hard slab. Mostly I lived with it, we're talking sole plates and the mostly driven nail had them tightly pinned to the floor, with studs on top the wall isn't going anywhere . After a while I got some shorter nails, 2.5 inchers will go in all the way in a hard slab.
Or move the the .25 caliber gun
Mdbuilder is offline   Reply With Quote
Old 02-07-2008, 02:57 PM   #10
Rewards Points: 5,336
Agree with the 2 1/2" nails and also the addition of construction adhesive.
Ron
Old 02-07-2008, 10:46 PM   #11
Exclamation
i am using .27 caliber ammo.
Old 02-07-2008, 11:33 PM   #12
ICF Construction
What kind of gun are you using?
I first used many years ago a Remington from the infamous retailer, it was a P.O.S. Spent some really money on a Simpson PT27, gun actually is quiter, less shot issues.
It can all be in the quality of the tool
Chris
Chris Johnson is offline   Reply With Quote
Old 02-07-2008, 11:39 PM   #13
Exclamation
remington 496, bought used on ebay.
thanks,
- a -
Old 02-08-2008, 08:23 AM   #14
thanks,
- a -
That's a .27 cal. uses auto feed fastener strips. We have one.
Make sure that you clean it up good and use the correct power loads for the gun.
- Build Well -
Old 02-08-2008, 07:33 PM   #15
General Contractor
joasis's Avatar
If you leave a nail up, you can cycle the gun and place it over the nail and give it a second shot....sometimes concrete is just a bear to shoot fasteners into....I use Ramsets, and they usually hit it the first time, except on steel. The double tap is not really recommended as being good for the gun. Take care with anything you do when using a power actuated fastener.
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
joasis is offline   Reply With Quote
Pressure treated posts set in concrete? zubin6220 Building & Construction 19 08-13-2013 06:39 AM
shooting nails through 2x4s into concrete amakarevic Building & Construction 6 01-28-2008 10:52 PM
new concrete floor next to old concrete floor mattroos Building & Construction 10 08-28-2007 02:32 PM
Aluminum Door sill and Concrete Dragon Building & Construction 2 01-06-2007 01:55 PM
Need to expand existing concrete pad for A/C unit miketegra Building & Construction 2 07-03-2005 11:27 PM
