Shooting Nails Through 2x4s Into Concrete - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-28-2008, 05:00 PM   #1
Rewards Points: 1,062
Question
shooting nails through 2x4s into concrete
i have a remington powder-actuated nail gun for fastening 2x4 into concrete.
Q1: which size nails should i use (3.5 in perhaps) ?
Q2: which strength ammunition should i use (1-6) ?
bonus Q: if the vertical 2x4s are called studs, what do you call the horizontal ones that get fastened to the floor ?
thx,
- a -
Old 01-28-2008, 07:21 PM   #2
Sill Plate... don't know about the nails or the power setting.
jack
MrLinux is offline   Reply With Quote
Old 01-28-2008, 07:48 PM   #3
Neanderthal Woodworker
woodman51jfk's Avatar
2.5 to 3.5 will suffice....red powder loads, be sure to get the pins with washers installed. A bead of adhesive helps seal the sill, also.
woodman51jfk is offline   Reply With Quote
Old 01-28-2008, 08:21 PM   #4
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Originally Posted by amakarevic View Post
Q1: which size nails should i use (3.5 in perhaps) ?-
Use the 3-1/2" COATED nails. Make sure that they are coated/treated or galvanized, or the PT lumber will cause them to corrode. There is no need to use washers.
Q2: which strength ammunition should i use (1-6) ?-
That depends on the concrete. I would suggest that you get several boxes of #2, #3, #4.... and return what you don't use. # 3 charge is about average for basements and PT 2x4 attachment.
bonus Q: if the vertical 2x4s are called studs, what do you call the horizontal ones that get fastened to the floor ?-
They are called " plates".
Top = top plate
Bottom = bottom sill plate, or sole plate
Good luck on your project.
- Build Well -
Old 01-28-2008, 10:39 PM   #5
If the concrete is well cured, requiring the use of red loads ( #5 or #6 depending on manufacturer/style/caliber ), as in most remodeling scenarios, the use of the washered pins is recommended, and in fact required in some areas, even in new construction..........but then I can only refer to Southern Building Code here in Texas for recommendations, along with 42 years experience in the building trades.........didn't see any reference to using PT.........just 2X
Old 01-28-2008, 10:50 PM   #6
of course, PT
required in my municipality.
thx,
- a -
Old 01-28-2008, 10:52 PM   #7
.that being the case, absolutely agree with using coated pins.....
Sleeve options for plumbing through concrete? Bruce L Plumbing 6 06-14-2008 10:38 AM
new concrete floor next to old concrete floor mattroos Building & Construction 10 08-28-2007 02:32 PM
stone veneer formula tom1st Landscaping & Lawn Care 1 07-08-2006 05:48 PM
Need to expand existing concrete pad for A/C unit miketegra Building & Construction 2 07-03-2005 11:27 PM
