-   -   shooting nails through 2x4s into concrete (http://www.diychatroom.com/f19/shooting-nails-through-2x4s-into-concrete-16300/)
amakarevic 01-28-2008 04:00 PM
i have a remington powder-actuated nail gun for fastening 2x4 into concrete.
Q1: which size nails should i use (3.5 in perhaps) ?
Q2: which strength ammunition should i use (1-6) ?
bonus Q: if the vertical 2x4s are called studs, what do you call the horizontal ones that get fastened to the floor ?
thx,
- a -
MrLinux 01-28-2008 06:21 PM
Sill Plate... don't know about the nails or the power setting.
jack
woodman51jfk 01-28-2008 06:48 PM
2.5 to 3.5 will suffice....red powder loads, be sure to get the pins with washers installed. A bead of adhesive helps seal the sill, also.
AtlanticWBConst. 01-28-2008 07:21 PM
Originally Posted by amakarevic (Post 92946)
Q1: which size nails should i use (3.5 in perhaps) ?-
Use the 3-1/2" COATED nails. Make sure that they are coated/treated or galvanized, or the PT lumber will cause them to corrode. There is no need to use washers.
Q2: which strength ammunition should i use (1-6) ?-
That depends on the concrete. I would suggest that you get several boxes of #2, #3, #4.... and return what you don't use. # 3 charge is about average for basements and PT 2x4 attachment.
bonus Q: if the vertical 2x4s are called studs, what do you call the horizontal ones that get fastened to the floor ?-
They are called " plates".
Top = top plate
Bottom = bottom sill plate, or sole plate
Good luck on your project.
woodman51jfk 01-28-2008 09:39 PM
If the concrete is well cured, requiring the use of red loads ( #5 or #6 depending on manufacturer/style/caliber ), as in most remodeling scenarios, the use of the washered pins is recommended, and in fact required in some areas, even in new construction..........but then I can only refer to Southern Building Code here in Texas for recommendations, along with 42 years experience in the building trades.........didn't see any reference to using PT.........just 2X
amakarevic 01-28-2008 09:50 PM
of course, PT
required in my municipality.
thx,
- a -
woodman51jfk 01-28-2008 09:52 PM
.that being the case, absolutely agree with using coated pins.....
