Shingled Roof For A Pole Barn - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-14-2013, 12:52 PM   #1
shingled roof for a pole barn
I have a pole barn with a metal roof & foamed insulation inside. What is the best way to put a shingle roof on top of the metal roof. thank you. tom
tdbell is offline   Reply With Quote
Old 08-14-2013, 09:22 PM   #2
AHH, SPANS!!!
Rewards Points: 1,166
best to take off metal and sheath roof with sheathing before shingle roofing is applied. pitch needs to be no less than 4 pitch per foot with shingles.
hand drive is offline   Reply With Quote
Old 08-14-2013, 11:25 PM   #3
Rewards Points: 2,210
It can be less then 4/12 pitch but not recommended especially in areas with snow load.
What is the spacing on the strapping that the metal is screwed to? Would be good if it was 16" as your sheets of plywood or OSB are 4' by 8'
Some pole sheds are strapped on 18" or even 20" or 24". Which does not work well. You can add another strapping where needed for the edge of the sheets.
mae-ling is offline   Reply With Quote
Old 08-15-2013, 09:36 AM   #4
roofingquotes's Avatar
I'd go for hand drive suggestion to take off the metal before putting shingles on roof.
roofingquotes is offline   Reply With Quote
Pole Barn Maine 2012 adimice Project Showcase 1 11-10-2012 07:38 AM
My old barn roof collapsed starchild General DIY Discussions 5 02-08-2011 02:15 PM
Putting a new flat roof on a 3600 sf home Jean3 Off Topic 2 04-09-2010 01:35 AM
Pole Barn cost nparent1 Off Topic 1 03-24-2010 08:27 AM
Pole barn no walls just roof 24X36 nrgeek Building & Construction 12 02-25-2009 01:15 PM
