Shingle 1 Pitch Roof - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-01-2009, 06:20 PM   #1
shingle 1 pitch roof
The roof on this trailer is a 1 pitch, it doesn't get that much wind on it where its located. I know shingling a roof on such a low pitch voids the warranty but how many more issues should I worry about.
Toolmaster is offline   Reply With Quote
Old 04-01-2009, 06:30 PM   #2
remodeling pro
Can you say leak? Such a low pitch will not shed water fast enough and you will get water under the shingles. If you want the shingles, you will have to first cover the roof with a self sealing membrane (ice and water shield) which will provide an effective water barrier beneath the shingles. What is on the roof now (typical trailer metal)? Be sure you have enough substrate for nailing to.
troubleseeker is offline   Reply With Quote
Old 04-01-2009, 06:33 PM   #3
yes just old school trailer metal, trying to save this friend money, wont know what Im getting into until this weekend. Inside the trailer you can see some water damage, Im pretty sure that she wants shingles, also wants me to take off existing siding and put new.
Old 04-01-2009, 06:43 PM   #4
General Contractor
HWConstruction's Avatar
If the trailer is old enough to have the old thin metal roof, then you can't shingle it. As said it will leak. Secondly there isn't anything to nail to. You would have to put on decking and then shingle, and that roof system WON'T support the weight!
HWConstruction is offline   Reply With Quote
Shingle Roof Replacement Questions - Overlay vs Tear-Off /OC vs Tamko tecboy Roofing/Siding 12 06-28-2009 06:09 AM
Flat roof questions, advice, ballpark estimate JerryH Roofing/Siding 18 11-07-2008 04:08 PM
Building Roof over Roof, changing pitch Thomas O Roofing/Siding 7 03-05-2008 09:51 PM
