Shimming Floor Joist - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-28-2012, 12:21 PM   #1
Shimming floor joist
I am on the back half of a main floor / kitchen renovation, and am in the process of putting down the new bamboo nail-down floors. Part of the house is old 3/8" plywood, so in the kitchen, I have put down underlayment on top of the 6" wide tongue-and-groove sub-floor to give a flat surface.
When I put this down, it felt like the floor had a dip in it in the middle, and sure enough, putting a 4' level across the floor, I noticed in the center the floor height was 1/4" lower than the edges. So after freaking a bit, and ruling out water damage (none), I noticed that one of the 2x8 joists is 7 1/4" thick instead of 7 1/2" like all the others in the room. It is this way for 2 feet, and then starts thickening to the full 7 1/2" by the 8' mark.
So... I assume that I can just shim this up, but wanted to make sure before I got started. Is it just good enough to shim under each 1x6" subfloor plank with cedar shims from each side of the joist? Or is there something else that I should do (shim and then sister a 2x8 to this floor joist? The joist is sturdy and has no issues, while sistering would be a major pain since there is a ton of electrical cables and water lines and heating ducts running through this area.
Thanks.
joeh is offline   Reply With Quote
Old 02-28-2012, 12:34 PM   #2
Rewards Points: 150
Or, you can pour some self levelling cement? Might be an easier option to bridge the sag.
psilva8 is offline   Reply With Quote
Old 02-28-2012, 06:52 PM   #3
Unfortunately, it's a nail-down hardwood, and I wouldn't want to think of nailing through that. I also hear self-leveling cement isn't so good on wood, so then changing a segment to glue-down wouldn't work either...
Old 02-29-2012, 08:13 AM   #4
Rewards Points: 150
I've used it on wood and had good results. You can glue the new hardwood in that area if you wanted. You need to make sure the sub-floor is screwed down tightly to the joists so it doesn't move, which would provide an adequate substrate for the leveller.
Or, you could lift and shim the joist as you suggested but this will be alot of work, and you may not get your desired result.
Shimming toilet?? dpach Plumbing 22 05-09-2012 03:17 PM
Shimming for ceiling drywall..Where to start??? RICKM15752 Drywall & Plaster 21 07-05-2011 07:45 PM
Excessive shimming to keep wall cabinets flush with one another? alexz Carpentry 10 12-22-2007 07:48 PM
Shimming Trimmers to Pass Framing Inspection? Ricky D Building & Construction 6 06-03-2007 09:55 PM
