Shelf On Rock Wall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-04-2009, 01:00 PM   #1
Shelf on Rock Wall
Shelf on Rock Wall
I have a rock wall floor to ceiling with a fireplace and want to know if it is possible to put a wood or log shelf above the fireplace. Is it possible to cut into the rock/mortar to install the brackets for shelf - does it compromise the rock's stability in any way? Or is it best to not do anything at all?
Karekel is offline   Reply With Quote
Old 08-04-2009, 02:53 PM   #2
Originally Posted by Karekel View Post
Shelf on Rock Wall
That would depend on what was used as "rock", Name:  fireplace.jpg
Size:  4.8 KB I installed some small shelving
during the build. also it would depend on the size of rock, if the rock was flat sided like mine you would chisel out and screw in your supports on the mason board, fit your rocks around the shelving, and mortar around the shelves. Usually if the rock is installed on a load bearing wall, the rock does not play a significant roll in support.
fstwrtr is offline   Reply With Quote
Old 08-05-2009, 05:07 AM   #3
Rewards Points: 4,578
yeah, sure its possible,,, be certain the rock's stable 1st, tho,,, unlikely, w/o actually SEEING the wall, to know how its blt/attached,,, you can but small diamond tipp'd core bits for rods to be inserted in the wall OR you can use carbide-tipp'd bits & hammer in the holes,,, i'd caution you to be VERY careful - if you've not donw this before, having a wall fall down's not pleasant & can ruin your afternoon
Shelf on Rock Wall Karekel General DIY Discussions 3 08-05-2009 05:17 PM
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 1 03-11-2009 04:48 PM
Retaining wall Limapapa Landscaping & Lawn Care 12 02-09-2009 03:01 PM
Fake rock for retaining wall epeterson777 Landscaping & Lawn Care 13 06-09-2008 11:49 AM
Low Retaining Wall cibula11 Landscaping & Lawn Care 3 07-29-2007 12:02 AM
