Sheets Of Foam Below Basement Floor - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-28-2011, 09:33 AM   #1
Sheets of foam below basement floor
I have loads of sand as a floor in my basement. I want to pour a 4 bag mix floor over 1 or 1 1/2 inch foam.
Should I?
1. Change the sand to gravel?
2. Place a 6 mill poly sheet down first or on the top of the foam?
3. What is exactly the name of the builders tape I should use to join the plastic poly together.?
4. Do I really need to put in a 6 inch wire mesh in the concrete?
5. How do I attach the plastic to the wall.?
mike2011 is offline   Reply With Quote
Old 03-28-2011, 01:41 PM   #2
Concrete & Masonry
Rewards Points: 470
Should I?
I would recommend an insulation like "Foamular 250", which is intended for concrete weight and only costs a tad more than the 15 psi foam.
It really depends on alot of variables. Does the basement have a draintile system?
Technically, the poly should be on the warm side of the insulation, so on top of the foam is the correct method per the book. Seeing as the actual ground-to-basement temp is relatively close, it doesn't matter near as much as above grade walls and ceilings. If there's a chance you'll damage the plastic during the pour, install it under the foam.
Most any duct tape will suffice, just lap the joints at least 6".
In a basement, no.
Just let a few inches run above the chalk line and it will stand on it's own. It can be cut flush w/ the floor later and caulked. OR, you can cut 1/2" thick foam insul. about 3-4" high and mount it beforehand to help hold the plastic & create an effective thermal break.
jomama45 is offline   Reply With Quote
The Following User Says Thank You to jomama45 For This Useful Post:
mike2011 (04-20-2011)
Did I need to use Foam board in basement? dbeers16 Building & Construction 8 01-04-2011 02:01 PM
Insulation in basement floor joists and integrated garage speedster1 Building & Construction 3 12-07-2010 06:44 PM
Basement floor drain causing me anxiety tondar Plumbing 1 06-21-2009 09:06 AM
New drains under the basement floor, guidance needed mason Plumbing 6 01-10-2009 05:58 PM
Basement floor reno D.RED Flooring 1 06-21-2006 03:20 PM
