Sheetrocking A Wall With A Window That Sticks Out - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-23-2009, 03:27 PM   #1
They're all fixer-uppers
J187's Avatar
Rewards Points: 516
Sheetrocking a wall with a window that sticks out
Old wall was plaster, the window comes out 1" so 1/2" drywall is obviously not going to match up for trimming. Seems like numerous ways to handle this, what is the most common, or the right way to do it? The way I see it, I can double up on the sheetrock on this wall only.. or I can add something under the moldings to make up the thickness, so I end up with a thicker molding...
J187 is offline   Reply With Quote
Old 03-23-2009, 03:51 PM   #2
Mold!! Let's kill it!
Rewards Points: 2,012
You can trim the jamb back to almost flush with the new wall surface, or add a strip to the back of the trim to build it up so it lays correctly on the jamb. For me, I wouldn't double the sheetrock.
Old 03-23-2009, 06:07 PM   #3
J187's Avatar
Rewards Points: 516
When you say trim the jamb back, you mean just cut a 1/2inch off of it?
Old 03-23-2009, 06:42 PM   #4
If the wall wasn't too large I probably actually would consider doubling the drywall. My biggest concern would be making sure the outlets still sat correctly, but other than that as long as the seams don't line up at all I think it's a fairly easy solution, assuming you have to drywall anyway right?
Ininkus is offline   Reply With Quote
Old 03-23-2009, 08:46 PM   #5
Tom Struble's Avatar
Rewards Points: 2,002
you could add a backband to the trim like the original probably had
Tom Struble is offline   Reply With Quote
Old 03-23-2009, 09:07 PM   #6
or I can add something under the moldings to make up the thickness, so I end up with a thicker molding... __________________
yep. thats the way to do it. some 3/4" stock by whatever the thickness you need to make up.
II Weeks is offline   Reply With Quote
Old 03-24-2009, 06:51 AM   #7
I've trimmed them back with a router and a flush trim bit. Screw a temporary 1x3 along side of the jamb for the router to ride on. Trim the jamb back so it stands proud of the wall surface by about a 1/16". Then sand the face a little.
Old 03-24-2009, 06:55 AM   #8
Rewards Points: 5,336
Add furring to the window wall to bump it out to the desired depth you want. 1/2 " ply would do for the depth you state.
Ron
Old 03-24-2009, 08:36 AM   #9
Rewards Points: 156
definitely furring
Go get enough 1/2" ply to cut furring strips and tack them to the studs before you hang the drywall.
jayp is offline   Reply With Quote
Old 03-24-2009, 08:57 AM   #10
Concrete & Masonry
Rewards Points: 582
I would either furr with 1/2" ply or plane the window jambs in place, or a combo of both is probably ideal. I've seen a few great finish carps hand plane the jamb extentions to just a hair above the plaster/drywall on remodel work. Seems like a foolproof method to me.
jomama45 is online now   Reply With Quote
Old 03-24-2009, 09:02 AM   #11
Rewards Points: 156
of course
You could also do the opposite of the drywall furring and fur the window mold. It will make it look super beefy.
"Defogging" double-pane windows .... a gimmick?? alexz General DIY Discussions 133 03-10-2010 12:35 PM
Considerations when pouring concrete against a stucco wall? clint_nichols Building & Construction 9 09-24-2009 05:28 AM
Window frame not flush with finished wall Stubbie Carpentry 9 06-24-2008 02:38 PM
Want to install larger window in basement wall andrewcocke Remodeling 8 02-24-2008 10:51 PM
Non-load bearing window header in exterior wall timelyirony Building & Construction 3 12-08-2007 04:15 PM
