Old 10-17-2009, 05:30 PM   #1
Sheetrock over Homasote
I have an attached two car garage that shares 1 common wall with my home. The hose and garage was built in 1957. The shared wall between the house and garage is not insulated. The garage was finished in homasote which (except for the ceiling) has been removed. I am in the process of replacing two windows, one rear entry wooden door and the garage door. In addition, I am unsulating the exterior (2x4 16 on center) walls, running added electrical outlets and sheetrocking. I will use 5/8 fire proof for the entire job. My question is, I have not pulled the homasote from the ceiling with the hope that I would not have to and could sheetrock right over it - mostly to save time and a mess. Does anyone know if this is okay or am I just asking for trouble later on. The ceiling rafters are all 2X10 (believe it or not).
Uihlein is offline   Reply With Quote
Tags
firewall, garage, sheetrock
Do I repair or replace wet sheetrock? no clue at all Drywall & Plaster 7 02-06-2010 11:54 AM
Using nail Gun on sheetrock jwshome Building & Construction 12 09-08-2009 10:16 PM
Mounting a flatscreen TV on a sheetrock wall TanMan Building & Construction 14 02-16-2009 05:26 PM
sheetrock over sheetrock add insualtion? monkeywrench Remodeling 18 11-30-2008 10:19 AM
New medicine cabinet--old plaster and sheetrock help! garyofnyc Remodeling 4 10-31-2008 11:15 PM
