Sheetrock Compound How Cold? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-09-2008, 06:18 AM   #1
Question
Sheetrock compound how cold?
I'm rough finishing part of my barn, insulating and starting to put up some sheetrock, adding some heat but it will only be heated while I'm in it a few hours at a time. Here in upstate NY we can have cold spells where it gets below zero for a few days with highs in the teens and in the summer it may get above 90 for a few days. I was wondering if joint compound would stand the temperature extremes. \
jerry
romer jt is offline   Reply With Quote
Old 05-09-2008, 07:50 AM   #2
Mold!! Let's kill it!
Rewards Points: 2,012
Once it cures it should be OK. I'd be more concerned with dampness infiiltrating the drywall as it goes from warm to cool over and over. You'll be driving moisture in and out of the drywall on a repetitive basis. Maybe someone else can comment further, but I have seen instances where that became a problem.
Tags
sheetrock compound , temperature
Hot Water in Cold Water Lines ??? Superbuuck Plumbing 14 08-29-2011 01:21 PM
Applying Drywall Compound To Sheetrock shapeshifter Painting 9 04-29-2008 04:42 AM
Help with low pressure cold water upstairs lewissv Plumbing 5 01-26-2007 09:05 AM
How to deal with setting drywall compound? KUIPORNG Remodeling 11 01-11-2007 09:22 AM
