Sheet Foam Insulation - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-03-2010, 06:41 PM   #1
Question
Could anyone tell me the difference between sheet foam insulation?
On my last visit to Menards I noticed three different types of sheet foam...White, Pink, Blue...
I'm not interested in the technical information I just need someone in the know to advise me which one would be best in a boating situation...
I'm planing a homemade boat project that uses foam as the boats hull core, with plywood and fiberglass over the hull...(Weight and water retention are my main concerns)
I posted this question here too http://www.diy-questions.com/index.php/topic,6.0.html but there are just getting started and have no one to help me yet.
All help will be appreciated...
RDGreen is offline   Reply With Quote
Old 09-03-2010, 11:09 PM   #2
Perhaps you could check out foam used for docks. match up the specs with what they sell for marine apps and see if something similiar and cheaper at building supply.
eastside is offline   Reply With Quote
Old 09-04-2010, 11:56 AM   #3
Rewards Points: 1,092
pink and blue foam are from two different companies who make the same stuff; XPS. you want that for a boat; water proof. white boat is ESP; not water proof.
Old 09-05-2010, 12:33 PM   #4
Rewards Points: 212
I recommend you do some research on boat building with foam or foam sandwich. You do not want a foam (plastic) that is dissolved by
other products (polyester resin etc.)
Here's a link that may get you further info.
http://www.bateau2.com/howto/foam1.php
Good luck.
orange is offline   Reply With Quote
Old 09-06-2010, 06:48 PM   #5
Totally screwed together
i think the foam you need is Polyurathane. Eve more waterproof than the pink/blue.
xxPaulCPxx is offline   Reply With Quote
spray foam insulation mikeybobo Building & Construction 11 06-19-2010 05:04 PM
Fishing Wire - Foam Insulation bohaiboy Home Theater 14 01-18-2010 06:41 PM
Installing Rigid Foam Insulation and Drywall raheel Drywall & Plaster 3 02-16-2009 07:07 AM
rigid foam insulation in walls gossamer Building & Construction 12 02-03-2009 10:26 PM
Spray in foam insulation leted_82 Building & Construction 3 05-31-2007 11:14 AM
