sheer strength 10d .12 dia
The shear strength of a 10d is a lot more than the wood that it's shoved into.
If you have ever banged a stud out that was end nailed, you would have seen that the nails bend...not shear off. The wood is giving which allows the nail to bend and pull out.
Common Sense is like Deodorant. Those that need it the most don't use it.
My To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. ... To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. and To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
