Sheds - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-20-2012, 06:00 PM   #1
Keith loynes's Avatar
sheds
what kind of timber would i use for my shed frame
Keith loynes is offline   Reply With Quote
Old 01-20-2012, 06:17 PM   #2
Residential Designer
AndyGump's Avatar
Rewards Points: 662
Send a message via Skype™ to AndyGump
Wood is usually my first choice.
Sorry, I just don't know what you would use.
Andy.
AndyGump is offline   Reply With Quote
Old 01-20-2012, 06:19 PM   #3
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
Framing lumber.
Order 4 12' treated 2x4's
40 2x4x16 #2 pine
12 2x6x14 " "
14 4x8x7/16" osb
Concrete, roofing, nails, trim, door, window, padlock, paint, misc.
Pour concrete. Build shed. Roof.
Enjoy!
(disclaimer: this may be too much lumber, or not enough, depending on size of shed, etc.)
titanoman is offline   Reply With Quote
Old 01-20-2012, 06:26 PM   #4
MarginallyQualified
Rewards Points: 2,464
well, if he limits himself to the 8' x 10' pad that one yard of concrete (in the buggy) will fill to 4"... then 4 or 5 10' 2x4's will be enough (use the extra for bracing) to form up that pad. Lets solve one problem at a time.
maybe you should buy a measuring tape, square, level, twine, line level, shovel, rake, bull float, finish trowels... yeah, you better build that shed soon with all those tools sitting out in the yard.
Old 01-20-2012, 06:28 PM   #5
Rewards Points: 506
Douglas fir. Treated lumber for anything on the floor/ground.
jlmran is offline   Reply With Quote
Old 01-20-2012, 06:29 PM   #6
Rewards Points: 506
Is OSB considered framing lumber? Or sheathing?
Old 01-20-2012, 06:46 PM   #7
Disabled wood vet
titanoman's Avatar
Well, it's all pine around here. All DF in Cali.
Old 01-20-2012, 06:47 PM   #8
Disabled wood vet
titanoman's Avatar
sheeting and sheathing (roof/walls)
Old 01-20-2012, 06:54 PM   #9
Rewards Points: 506
I was being facetious...while regarding the OPs question. He asked only about the frame.
Old 01-20-2012, 07:30 PM   #10
Disabled wood vet
titanoman's Avatar
Oh! I hope I didn't confuse him too much!
Foundation for 8x10 Vinyl Shed fireberd350 Building & Construction 17 03-04-2012 05:49 PM
building code and sheds WillK Building & Construction 4 06-18-2011 01:25 AM
New & Old Sheds joined to make an 'L' rider75 Building & Construction 5 05-27-2011 08:54 AM
Building storage sheds hlevario Building & Construction 1 03-01-2011 08:12 PM
Backyard Sheds rjordan393 Building & Construction 6 09-16-2010 02:10 AM
