Shed Truss Fascia And Overhang Framing - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-23-2010, 04:23 PM   #1
Shed Truss Fascia and Overhang Framing
So I am building a shed as a project, no plans, just from scratch. I am getting prefabbed trusses for various reasons and have a general idea of how to frame up the overhangs, but I am sure I will miss something and I really don't want to mess it up. It will be a 4/12 pitch with a 12 inch overhang on all sides of the 8 x 12 shed. Does anyone have a good how-to guide, preferably with pictures? How about some pictures of it framed up before covered so I can see it all together?
Thanks so much!
TANC is offline   Reply With Quote
Old 01-24-2010, 08:27 AM   #2
Rewards Points: 5,336
The overhangs can be incorporated into the trusses when they're built..
Ron
Old 01-24-2010, 08:35 AM   #3
i would use drop truss on gable ends so overhang doesnt sag
Old 01-24-2010, 10:32 AM   #4
Rewards Points: 1,016
Sometimes gable end trusses are made 1-1/2" or 3-1/2" shorter than the other trusses you order. That's to help you extend the roof out a few inches over the gable end.
See the rest of the article with gable end pictures at:
http://www.hometime.com/Howto/projec...ng/frame_5.htm
Old 01-24-2010, 11:04 AM   #5
"Beam me up, Scottie"
Kevin M.'s Avatar
Rewards Points: 150
Me too.
Look on page 12 under drop chord gable truss.
http://www.allpan.com/res/FramingWithRoofs.pdf
Kevin M. is offline   Reply With Quote
Old 01-24-2010, 02:25 PM   #6
Good to know about the shorter end trusses. What about finishing off the ends with the fascia boards and preparing for install the soffit vents and associated framing.
Boxing in overhang Uncle David General DIY Discussions 3 10-24-2009 07:05 PM
Help with installing aluminum soffit and fascia Boontucky Roofing/Siding 3 09-01-2009 07:47 PM
Vinyl over fascia, how to finish overhang? patrickogrady Building & Construction 4 08-23-2008 07:00 AM
tight overhang clearance on gable abutment - how to cover...? rtoni Roofing/Siding 7 10-11-2007 11:13 PM
Roof sheathing overhang on fascia Clutchcargo Roofing/Siding 7 08-23-2007 01:02 AM
