Old 02-01-2008, 05:27 PM   #1
Shed setback from prop lines?
Hi All,
Is there a rule about how far from your property line you can have a shed? I know it depends on the city or town but I just thought that there may be an average.
sandyman720 is offline   Reply With Quote
Old 02-01-2008, 06:12 PM   #2
in my neighborhood its 4' from back and 2' from side, and there are height restrictions too, but it varies dramatically. you usually need to contact the zoning section of your building code dept. to find the answer to your setback requirements (if you're lucky you can find it on line if your jurisdiction is up on the web)
nacko is offline   Reply With Quote
Old 02-01-2008, 06:37 PM   #3
Originally Posted by sandyman720 View Post
Hi All,
Even if there is an "average" how would that help you?
Here it's 10' from any property line, no permit required if 100 sq. ft. or less. No taller than 10' . But a detached 1 or 2 garage can be built 12" from a side or rear yard PROPERTY LINE, GO FIGURE.
LawnGuyLandSparky is offline   Reply With Quote
Old 02-01-2008, 07:04 PM   #4
Long-Time DIYer
Mike Swearingen's Avatar
Check with your local Building Inspection Department for code, permit and inspection requirements, if any.
Mike
Mike Swearingen is offline   Reply With Quote
Old 02-01-2008, 07:49 PM   #5
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
As Mike stated, check in town.
This most definitely is not something that anyone here can answer for you, even if we were your next door neighbor.
Each area/town/city has it's own setback requirements. There are also "grandfathered" clauses that can allow you to install a shed closer than other properties, etc...Check your local city department...
- Build Well -
Old 02-01-2008, 09:16 PM   #6
Plus easements specific to your property.
Tscarborough is offline   Reply With Quote
Old 02-02-2008, 07:38 PM   #7
Here is is 64 square feet and less than 8 feet tall or all standard set backs apply, so you definitely need to check local codes.
kgphoto is offline   Reply With Quote
Old 02-02-2008, 08:57 PM   #8
Here it is 5' and 6' and you need a permit for a dog house
Definitely call into your code enforcement office
ocoee is offline   Reply With Quote
Blue Chalk Lines on concrete Triple L Flooring 3 10-09-2007 06:50 AM
Shed: One light, one plug Crackers Electrical 2 08-31-2007 06:09 PM
Subpanel to Shed - Check my plan NateHanson Electrical 9 04-26-2007 10:56 PM
Venting a shed roof with 2/12 slope atulc Roofing 5 08-25-2006 08:28 AM
increasing washer supply lines to 3/4" instead of 1/2" amatchin Plumbing 3 04-15-2006 05:23 PM
