Old 05-10-2011, 09:40 PM   #1
Shed Roof Truss
I am building a 12 by 8 shed... The actual shed will be 12 by 80 with a small porch on the front.
What I have been struggling with is the roof truss' Can anyone provide some advice on the roof truss'?
Since I have will have an overhang in the front of 19 inches (the framing is actually 8 foot 3 inches) I have been unable to find any examples for the truss' I would like to have some storage space above...
I thought I could build the outside truss' as a complete triangle and the middle 2 without the bottom 2 by... (?)
Tonight, I cut 2 2x4's @ a 26.5 angle and matched them together.. I then took another 2x4 which was cut to 9 foot 3 inches (1 foot overhang on the back) and determined where I should cut the other 2 2x4's..
I am an experienced diy'er but have never worked on a roof before
I plan on building the walls @ 7 foot high... Any advise would be greatly appreciated!!!
Thanks!!!
Fred
FKampf is offline   Reply With Quote
Old 05-11-2011, 08:17 AM   #2
Shed Roof Truss
I'd bring the plans to the local lumberyard and have them order the trusses you need. I don't see any truss engineering experience in your post.
Ron
Old 05-11-2011, 08:46 AM   #3
Shed Roof Truss
Thanks for responding Ron.. your right, I dont' have any truss building experience.. However, I don't think that would prevent me from building them. I just need to figure out the proper way to go about it.
I did check with a lumber yard and the cose was $550 for 7 trusses. The guy @ the lumber yard told me that I should be able to build them myself. Just need a little help with the plans.
Thanks again!
Tags
roof truss
Roof leak nightmare..... it won't stop amandat37 Roofing 52 04-22-2011 01:47 PM
Newbie roofing a shed with a gambrel roof tomseeley Roofing 2 09-08-2010 01:11 PM
Putting a new flat roof on a 3600 sf home Jean3 Off Topic 2 04-09-2010 01:35 AM
how to purt a shed roof on a deck gbeach Building & Construction 11 07-09-2009 10:53 PM
How much snow can my shed roof support? Critter68 Building & Construction 6 10-15-2008 10:53 PM
