Shed Roof Question - Rafter Layout - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-27-2012, 04:59 PM   #1
Shed roof question - rafter layout
Actually this is to be a greenhouse.
I'm a bit nervous about the way the rafters sit on the wall.
Do you think a supporting block screwed to the wall studs would help - if so how would you go about screwing it - the block would be 3 1/2" wide.
Cheers!
Octavius is offline   Reply With Quote
Old 04-27-2012, 05:59 PM   #2
Rewards Points: 636
if no over hang i adjust my rafter so the part you are proposing to put block under lands on top of wall then cut tail of rafter so it is flush with outside of wall.
i also will put a simpson strong tie h1 on the inside of wall on rafter layout before installing rafters to make it easy to hold on layout to nail rafter to wall then go back after all are set and nail hanger to rafter.
link to h1 hanger
http://www.google.com/products/catal...ed=0CEEQ8wIwAw
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is offline   Reply With Quote
Old 04-27-2012, 06:23 PM   #3
Rewards Points: 13,444
The drawing your showing has the rafters cut wrong. It should look like this.
http://images.search.yahoo.com/image...mb=cpCLpHoH11V
Old 04-27-2012, 09:40 PM   #4
In a little over my head
Rewards Points: 706
Will you be using ceiling joists or collar ties? Or a post under the ridge? What will keep the roof from trying to spread the walls?
ratherbefishing is offline   Reply With Quote
Old 04-28-2012, 05:16 PM   #5
Thanks for the replies!
Jay,
Good idea about having the rafter fully supported and the sharp end cut off. Also the ties. I'll do both.
Joe,
Yeah, I know what you mean - your way also provides for a gutter system if necessary and it also looks a lot better. However, this is a green house and I think the original designers thought an overhang would cut out too much light to the plants inside.
RatherBeFishing,
Well, they are not included in the original plans:
http://www.buildeazy.com/greenhouse5-1.html
But I was a bit nervous about the two rafters just being held together with a piece of plywood so I was actually thinking of collars ties, 1x4" would be OK, right? I never thought about the roof pushing the walls apart - wow! Would collar ties prevent that?
Here's another view with detail of the first rafter. The long rafters are joined with metal strapping and the short ones with blocking.
Cheers!
Old 04-28-2012, 05:32 PM   #6
2 X 6's would be better for collor ties, Less likly to split when nailed.
Without some over hang all the water running off the roof is going to end up running down the widows and siding which will end up causing problums.
Your also far better off having this shed no closer then 8" to the ground.
If not the sidings going to rot out.
Old 04-28-2012, 05:52 PM   #7
cortell's Avatar
Rewards Points: 504
Collar ties must be min 1x4. Most builders use 1x4, from what I've seen. 2x6 seems like serious overkill
cortell is offline   Reply With Quote
Old 04-28-2012, 06:32 PM   #8
Joe,
Well, I didn't want to go with pressure treated wood but I think I'll have to. Thanks for pointing out the limitation of that roof design.
Cortell,
Thanks - I think I'll go with 1x4"s and use deck screws to attach to the rafters.
Cheers!
installing a metal roof on a shed will02 Roofing/Siding 15 04-08-2014 02:41 PM
Shed Roof Fascia and Framing Question crhage Building & Construction 3 06-22-2011 06:54 AM
roof rafter rot fix snosurfa7 Roofing/Siding 2 05-19-2011 06:26 AM
Shed Porch roof tying in... my5sons Roofing/Siding 7 10-27-2009 08:19 PM
The moving Ice Dams after using a roof rake ?? Canufixit Roofing/Siding 9 02-05-2009 07:33 PM
