Shed Roof Pitch Question - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-16-2013, 11:10 AM   #1
Shed roof pitch question
Hi - I'm new to shed building, and I'm building a 9x12 storage shed with a shed roof. Roof will be metal on top of 5/8 plywood. Rafters are 2x8, spaced 12" oc. Ridge plate and lower plates are 4x6 doug fir. The ridge and lower plates run along the 12foot side of the shed. The shed will be in central WA, where we can get up to 2+ feet of snow (not usually very high water content) at a time on occasion. The shed is positioned so any snow can slough off safely.
My question is regarding roof pitch. Can I get away with a 4/12 pitch (actually 4.25/12)? As the project stands now, I can attain a 5/12 pitch but this would require some deconstruction and reconstruction.
Thanks for your help!
Kevin P. is offline   Reply With Quote
Old 05-16-2013, 06:50 PM   #2
GBrackins's Avatar
Rewards Points: 2,108
Welcome to the Forum!
the more the pitch the better for removal of snow ..... can I ask why 9', gonna waste some building materials that way
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 05-16-2013, 09:28 PM   #3
Msradell's Avatar
Rewards Points: 278
What you have should be fine, especially since you're using metal roofing, which has a low coefficient of friction. But as GB said, the more slope, the better, especially in areas where you get that much snow.
Msradell is offline   Reply With Quote
The Following User Says Thank You to Msradell For This Useful Post:
Kevin P. (05-17-2013)
Old 05-17-2013, 08:07 AM   #4
Rewards Points: 3,130
Well, 2-5 feet of snow over a whole winter isn't that much unless it all falls in a couple of days. Where I live (Eastern WV) we can get that much or more over a winter, but it's seldom more than 6-8 inches at a time. That said, about three years ago we had 5 feet during a single 3-day storm. We're in a rural mountain area, and were snowed in for 6 days. And believe it or not, though our log home has a 12/12 pitch metal roof, the entire 5 feet of snow stayed on the roof for a couple of days. Closest I've ever been to an avalanche was when it came down all at once.
Old 05-17-2013, 10:19 AM   #5
[QUOTE can I ask why 9', gonna waste some building materials that way[/QUOTE]
I am putting the shed on a pre-existing 10x12 concrete pad, and wanted to maximize my space without needing a building permit (under 120sq ft).
Old 05-17-2013, 10:21 AM   #6
GBrackins's Avatar
ok .... do you know what building code you are under? where are you located?
Gary
Old 05-17-2013, 10:23 AM   #7
We can get up to 2+ feet at at time on occasion, with more likely scenarios being 8-12 inches, several times a week during storm cycles. Our cabin held 30 inches during a 2 week cold snap last year.
Old 05-17-2013, 10:25 AM   #8
We're in central Washington.
Old 05-17-2013, 10:44 AM   #9
GBrackins's Avatar
I ask because the State of Washington uses the 2009 International Residential Code, see link https://fortress.wa.gov/ga/apps/sbcc/Page.aspx?nid=14
here is a link to the 2009 IRC http://publicecodes.cyberregs.com/ic...9_1_sec007.htm
Section R105.2 of the 2009 IRC exempts the following from permits:
R105.2 Work exempt from permit. Permits shall not be required for the following. Exemption from permit requirements of this code shall not be deemed to grant authorization for any work to be done in any manner in violation of the provisions of this code or any other laws or ordinances of this jurisdiction.
Building:
1. One-story detached accessory structures used as tool and storage sheds, playhouses and similar uses, provided the floor area does not exceed 200 square feet (18.58 m2).
2. Fences not over 6 feet (1829 mm) high.
3. Retaining walls that are not over 4 feet (1219 mm) in height measured from the bottom of the footing to the top of the wall, unless supporting a surcharge.
4. Water tanks supported directly upon grade if the capacity does not exceed 5,000 gallons (18 927 L) and the ratio of height to diameter or width does not exceed 2 to 1.
5. Sidewalks and driveways.
6. Painting, papering, tiling, carpeting, cabinets, counter tops and similar finish work.
7. Prefabricated swimming pools that are less than 24 inches (610 mm) deep.
8. Swings and other playground equipment.
9. Window awnings supported by an exterior wall which do not project more than 54 inches (1372 mm) from the exterior wall and do not require additional support.
10. Decks not exceeding 200 square feet (18.58 m2) in area, that are not more than 30 inches (762 mm) above grade at any point, are not attached to a dwelling and do not serve the exit door required by Section R311.4.
have you discussed this with the building official? it is possible that Washington State allows local modification. Worth a call as every square foot in a shed is important. Even if they require a permit for 120 s.f. might be worth it.
oh a side note, exempting a building permit does not exempt any other permit such as wetlands, board of health, etc.
just my humble thoughts ....
Gary
Old 05-17-2013, 11:36 AM   #10
Thanks for the info, Gary.
Old 05-17-2013, 11:52 AM   #11
GBrackins's Avatar
they could be, some states have a state building code but local jurisdictions are allowed to modify it ...... what's the cost of a permit? doubt it should be much
Gary
Old 05-17-2013, 04:39 PM   #12
Roofmaster
Rewards Points: 2,210
Originally Posted by Kevin P. View Post
Thanks for the info, Gary. I agree with the info you posted, but I was specifically told by the County building department that I would need a permit for anything 120sq feet or greater. I wonder if Rural Residential codes are different?
Its about money. Did they tell you you needed a permit to brush your teeth? Oh, and I hope you did not use toilet paper without one, thats a definite No No.
Old 05-17-2013, 08:12 PM   #13
Ok...I'll bite, since it looks like my original post is getting hijacked - and it only took 24 hours!
I posted on this forum to get some advice from folks who don't mind sharing their experience, expertise, and knowledge of Building and Construction - not to get social commentary on why local governments collect fees.
Maybe a real "roofmaster" will have an on-topic answer to my newbie building question?
Best material for a 3:12 pitch roof extension? Nittany Roofing/Siding 7 05-31-2012 02:34 PM
Putting a new flat roof on a 3600 sf home Jean3 Off Topic 2 04-09-2010 12:35 AM
Shed Roof Truss Question Gravel7 Carpentry 1 10-08-2009 06:13 AM
Flat roof questions, advice, ballpark estimate JerryH Roofing/Siding 18 11-07-2008 04:08 PM
Building Roof over Roof, changing pitch Thomas O Roofing/Siding 7 03-05-2008 09:51 PM
