Shed Roof Pitch - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-03-2011, 12:00 PM   #1
Rewards Points: 1,062
Question
shed roof pitch
what would be the smallest pitch recommended for a garden shed, it is 11x9 in size?
thanks
Old 01-03-2011, 12:07 PM   #2
Stay-at-home GC
Would depend on where you are located. Snow loads?
CplDevilDog is offline   Reply With Quote
Old 01-03-2011, 12:15 PM   #3
Question
oh yes, sorry. Washington, DC. seldom more than 2 ft of snow.
thanks
Old 01-03-2011, 12:19 PM   #4
A Little Of Everything
Rewards Points: 1,364
thanks
There are several factors - not the least of which is what you're using for material and supports.
I just built an 8x12 shed this fall. I used 2x6 "rafters" on 16" centers. 5/8" plywood sheeting. It has a slightly less than 3-12 pitch.
Is there some particular reason you're wanting to go with the least pitch possible?
DrHicks is offline   Reply With Quote
Old 01-03-2011, 12:21 PM   #5
Smile
how does 3/12 translate into degrees ?
why smallest pitch? i don't want the shed to rise any higher than it has to.
thanks
Old 01-03-2011, 12:22 PM   #6
Stay-at-home GC
Also need proposed rafter layout. Trusses or stick, on center spacing?
Old 01-03-2011, 12:28 PM   #7
something like this:
http://www.buildeazy.com/shed_3.html
thanks
Old 01-03-2011, 12:28 PM   #8
thanks
I don't know for sure what the degrees would be. A 12-12 pitch (rises 12" in a 12" run) would be a 45 degree angle. So I assume that a 3-12 would be one-forth of that, or about 11 degrees.
There are many things you should consider with the roof of your shed. If you go with a gambrel/barn roof, you'll have more "off the floor" storage. Also, a higher pitch will give you better water/snow run-off.
I think you've got a good start - THINKING through what you want to do, and asking questions.
The Following User Says Thank You to DrHicks For This Useful Post:
amakarevic (01-03-2011)
Old 01-03-2011, 12:31 PM   #9
thanks
That's pretty much a twin to what I built, other than that mine is a lower pitch, and I extended the roof 3' over one side in order to cover firewood.
Old 01-03-2011, 03:42 PM   #10
Framing Contractor
3/12 is 14.04 degrees
4/12 is 18.43 degrees
Are the rafters spanning the 11' or 9' side?
Just curious as to why you want it in degrees.
What size rafters and ridge are you going to use? What will the overhang be?
Joe Carola
Joe Carola is offline   Reply With Quote
Need opinion on this roof profenx Roofing/Siding 14 10-12-2010 12:56 AM
12/12 Roof Pitch - cutting rafters JustAHack Building & Construction 11 10-06-2010 08:43 AM
Question: Altering One Side of a Gable Roof to a Shed Roof willcmjr Roofing/Siding 11 09-17-2009 04:32 PM
HELP - Finishing Row on a Shed Roof Makes More Work Roofing/Siding 5 06-25-2008 05:27 PM
Flat or shed roof Lonicera Building & Construction 2 12-23-2005 02:56 PM
