Shed Roof Insulation - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-10-2010, 09:34 AM   #1
Shed roof insulation
I'm trying to ready an 8'X12' shed into a usable workshop.
An insulation contractor told me that spray foam in the roof would eliminate the need for ventilation and a general contractor told me that rigid foam boards would do the same. I don't have enough head room to provide the ventilation needed and I'm not planning on much heat in cold weather. Just enough to keep things from freezing. Also, there is no ventilation built into this shed.
My question is, what is the best way to insulate this roof at the lowest cost? And, could someone please explain the need or no need of a vapor barrier in this application?
Is this a DIY'er project?
rcp612 is offline   Reply With Quote
Old 05-01-2010, 09:24 AM   #2
Question
Just a bump on this,,,,,, I can't believe no one has an opinion.
Old 05-01-2010, 05:45 PM   #3
Spray or rigid foam, makes no difference, except the spray is much more expensive, but less work!
The cheapest would be to use rigid and do it yourself! If you are hiring a contractor, I would spray as the labor cost would be less!
Using rigid requires cutting and fitting, plus caulking where the rigid meets the rafters. So, you don't want to pay contractors rates for the labor involved!
There, you go! That's my opinion!
The Following User Says Thank You to Wildie For This Useful Post:
rcp612 (05-01-2010)
Old 05-01-2010, 06:28 PM   #4
Registered User
Rewards Points: 4,936
Keep in mind some roofing shingle makers require ventilation for their warranty. V.B.: http://www.ecohomemagazine.com/energ...gy-claims.aspx
http://www.buildingscience.com/docum...ecommendations
Be safe, Gary
sloped roof insulation imtryingtofixit Roofing/Siding 10 04-01-2010 08:52 PM
Rafter Vents and Insulation nofx1981 Roofing/Siding 15 03-10-2010 09:14 PM
New Roof and Insulation over Existing Roof MitchellScott Roofing/Siding 1 05-03-2009 09:24 AM
How much snow can my shed roof support? Critter68 Building & Construction 6 10-15-2008 10:53 PM
HELP - Finishing Row on a Shed Roof Makes More Work Roofing/Siding 5 06-25-2008 06:27 PM
