Old 10-28-2011, 07:25 PM   #1
Shed roof construction questions
My Dad and I want to build a shed roof off his garage.
I plan to bolt a ledger on the building right underneath the rafter tails overhang and attach the rafters to this, then maybe flash the space between the existing roof drip edge and the new roof.
With the dimensions that he wants (10' 4" rafter span) and 6'6" of headroom under the header at the low end, I've calculated the pitch would be appx. 1 7/16".
Question 1: Is this is a problem? Can this tolerate a metal roof?
If so, what is the best way to frame this? Can I do 2X8 rafters 2' OC with horizontal 2X4 purlins every X inches, then metal right on that? Or would it need to be sheathed? If it needs to be sheathed, we would probably do some sort of "rolled" roofing.
If the pitch is a problem, the only alternatives are to either hang the roof right off the rafter tails (I don't like this structurally or visually), or build the roof right on top of the existing roof, and lap whatever material under the asphalt shingles. I don't like this either.
Thanks.
wombosi is offline   Reply With Quote
Old 10-28-2011, 08:43 PM   #2
Super Moderator
That pitch is a flat roof---the only safe roofing there is a rubber flat rood membrane.
Post a picture if you can---someone might have a suggestion.
Old 10-28-2011, 10:26 PM   #3
journeyman carpenter
woodworkbykirk's Avatar
torch on roofing can also be used.
in regards to flashing the space between the lower shed roof and the garage roof. most definitely. having one roof start directly below another needs to be treated as a single roof by having the joint sealed.. with the shed roof being such a low slow any sitting water can blow up into the gap between the shed roof and the fascia on the upper roof with heavy wind.. this would lead to a leak
woodworkbykirk is offline   Reply With Quote
Old 10-28-2011, 11:01 PM   #4
A Little Of Everything
Am I understanding you correctly, that this will be a 1-7/16" rise on a 12" rise? Or is it a TOTAL of 1-7/16ths over the entire span?
If it's a 1-7/16ths - 12" rise, you can probably get by with steel roofing - provided there are no seams. It's not ideal, but would probably work fine.
DrHicks is offline   Reply With Quote
No starter strip used on shed roof install? waterskier_erie Roofing 4 10-31-2011 09:25 PM
Drip edge for top side of Shed style roof with metal roof? organick Roofing 10 09-06-2011 09:43 PM
Shed roof stubits Roofing 1 07-14-2009 08:48 PM
Tie a shed roof into existing 6/12 roof jj1122_2000 Building & Construction 1 02-18-2009 10:37 PM
Which is better? (Non-vented roof construction with indoor pool) elbartee Roofing 21 03-27-2008 12:05 AM
