Shed Roof - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-22-2009, 03:45 PM   #1
Shed Roof
I want to frame a gable roof onto my (to be constructed) 12'x24' shed/storage/workhouse. To gain more headroom--by a longer rafter run-- I want to extend the ceiling joists to about 18" beyond the wall top plates on both sides; and nail the rafter seats to the joist ends. This will give me a longer rafter run and more loft space. I like a gable over a gambrel because it's easier to construct, work on, and doesn't collect as many leaves and branches. Ques: Will the joists support the roof weight w/o sagging? Seems like I've seen two-story houses where the top floor extended out beyond the lower story.
Hiflyer is offline   Reply With Quote
Old 05-22-2009, 04:35 PM   #2
Rewards Points: 5,336
You might want to tell us what size rafter you were planning to use. Maybe the roof pitch you were planning. Where you live for the snow load issue. If you have one.
Old 05-22-2009, 10:13 PM   #3
cantilever codes.
I think that I know what you want to do and it sounds like an okay idea. You will probably have to treat the ceiling joists the same as you would floor joists that cantilever over a wall and carry roof load. I think that 2x10's are probably required for this load . What are you planning on using for the ceiling joists?
Maybe a better way is to carry the roof load directly onto the walls by putting in a 2x4 vertical after you've done what you are talking about. Don't forget your gussets. Glued and stapled.
the carpenter is offline   Reply With Quote
ceiling joists , shed roof
The moving Ice Dams after using a roof rake ?? Canufixit Roofing/Siding 9 02-05-2009 07:33 PM
Flat roof questions, advice, ballpark estimate JerryH Roofing/Siding 18 11-07-2008 04:08 PM
Venting a shed roof with 2/12 slope atulc Roofing/Siding 5 08-25-2006 07:28 AM
