A Shed Re-furb - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-17-2011, 06:29 PM   #1
A Shed re-furb
Just looking to refurb a large shed in my back yard. I've identified some problems that need to be handled with it.
There are various components of the structure in varying stages of disrepair. I'm considering to start off by rehabilitating the exterior wooden components to a clean and healthy condition. Should I just strip, refinish and repaint? Or replace? These dark brown trim pieces are also in varying stages of damage or rot, and I am considering just removing them and putting up fresh pieces of 1x4? I also need to critter-proof underneath it, and would like some suggestions on that. Lastly, the plywood flooring, at the entrance edge, is sorta damaged and needs to be cleaned up. Can I do this without replacing the plywood sheet? Also, there are soffits on either side of the shed, but no ridge vent. Isn't this a problem?
Here's some pictures of the beast. It's footprint is 8' x 16' in total.
Thanks!
Cm1384 is offline   Reply With Quote
Old 04-17-2011, 06:38 PM   #2
Some more pictures....
This 100kb is killing me!
Old 04-17-2011, 06:48 PM   #3
Rewards Points: 5,336
Replace all you've pictured and any relatives in the shadows.
Prime all replacements before you install them, on all sides. Pay particular attention to the plywood edges.
Can't speak to the unseen floor.
Ron
Old 04-18-2011, 08:32 AM   #4
Rewards Points: 264
Trim definitely needs to be replaced. What we did with our church's shed was cut off and remove the bottom 2' of siding (part deteriorating from water/snow) with a chalk line and circular saw. Then dug a 12" trench around the base. We pulled the remaining siding out a bit to create a gap between it and the studs, cut Hardi board roughly 3' wide (8' lengths), and slid it up behind the siding and down into the ground. Hardi board doesn't require maintenance like wood and it should keep critters out from underneath. There are more permanent solutions but budget was the major project driver for the church. I really encouraged gutters to direct water away from the base but others didn't see it as necessary.
As for the ventilation, if you're worried about temp. difference inside and out you can certainly install ridge vent. On my own shed I went the route of adding gable vents, just seemed easier.
moneymgmt is offline   Reply With Quote
Moving an 8x10 wooden shed 100 miles; how? (Video of shed inside) snowfall General DIY Discussions 36 03-14-2017 01:39 PM
Drainage for Plastic Shed on Wooden Platform AikiPapi Building & Construction 7 07-29-2010 11:35 AM
wiring a detached shed for AC power *and* generator backhaul wrooster Electrical 19 05-28-2010 11:59 AM
Wiring a Shed and Garage abedj Electrical 1 05-08-2009 11:09 AM
Shed Wiring bcdal Electrical 12 03-26-2008 04:51 PM
