Shed Playhouse Question - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-26-2013, 03:11 PM   #1
Rewards Points: 396
Shed playhouse question
Hello everyone,
I am in the process of finishing a playhouse for my son and I am going to be putting it on a 2x8 deck base on my driveway using deck piers. My question is to level the deck piers is it ok to put shims under the piers or would I need to do a post beam and just level the posts?
detroittigerfan is offline   Reply With Quote
Old 07-26-2013, 10:48 PM   #2
Rewards Points: 6,652
You need a slight slope on it, so water will shed off the deck, but not so much that you can see it, nor too little, that water pools on the decking.
Old 07-27-2013, 02:57 PM   #3
Rewards Points: 396
This is a playhouse that is mounted to the deck so no water.
Old 07-27-2013, 04:47 PM   #4
kwikfishron's Avatar
Rewards Points: 90
You do not want to shim the piers, use the post to level the beam.
kwikfishron is offline   Reply With Quote
Moving an 8x10 wooden shed 100 miles; how? (Video of shed inside) snowfall General DIY Discussions 34 09-15-2015 07:23 PM
Shed floor question 416 Building & Construction 18 05-16-2013 11:02 AM
Shed Question -- Slab or Deck? jlaky2000 Landscaping & Lawn Care 7 02-17-2013 05:34 PM
Zoning issue with planned shed Ler0y Jenkins General DIY Discussions 15 02-01-2012 01:41 PM
Shed Project - Texture Question Niki H Drywall & Plaster 1 04-16-2010 12:07 AM
